Your last generator Maintenance Run
   / Your last generator Maintenance Run #2,221
Refreshing to see a couple of posts about generators and not about oil :D
   / Your last generator Maintenance Run #2,222
;) Here’s a pic of the partial enclosure I made to keep it a little dryer if it’s raining. Eventually I’ll build or find an inexpensive doghouse for it, leave it wired to my panel, and hook up a remote start switch in my basement. Going to use a power door lock actuator to operate the choke.
This works for now, keeps rain off the control panel and fuel tank.
   / Your last generator Maintenance Run #2,223
I'd sure like to see that, pics when you are done please.
and thanks for info about oil, you'd think when they said no we have no 15/40 they would have suggested what they had...
I have gallons and gallons of the 15/40 to use up before I try anything else but I'm in a warmer climate (usually) so not a lot of issues.
   / Your last generator Maintenance Run #2,225
JD Diesel Synthetic is on sale for $35.00 CDN, Regular $41.00 for a USG. On the one hand, my air cooled Diesel Yanmar may last longer with that oil, but what does last longer mean for something that is never used? Just $35.00 bucks spent.
And then, it may not get oil changes as often, on account of the cost. Generator does not have a filter.
   / Your last generator Maintenance Run #2,226
You bet! Will be tackling this project once the frost is out of the ground, in this order:
- Cement pad
- “Doghouse” - well vented of course
- Bury conduit to the basement with #6 wire
- build control panel for remote key switch/choke control
Ideally, I won’t need to leave the basement until the need for extra fuel arises.
   / Your last generator Maintenance Run #2,227
Mine is wired to the panel and on a cheap HF plastic dolly that only two of four wheels pivot. I roll it to the edge of my shed (basement extension) to be sure the exhaust vents outside.
Really need to fab a custom dolly. I have the casters and the metal... just need to draw up a plan and weld it together. A hood would be a nice option. That project just keeps falling lower on the priority list.
   / Your last generator Maintenance Run #2,229
Ran up my champion gen yesterday for about half an hour while I was out snowblowing. Didn’t have a load on it. I was impressed that it didn’t have any issues starting at -22C
Not to worry..... I hear that the guy who started the thread is an oil-geek too ;)
Rgds, D.
AIR LIFT 10 TON JACK (A55745)
AIR LIFT 10 TON...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
1979 MACK R MODEL (A53843)
1979 MACK R MODEL...
2018 John Deere 1653 (A55314)
2018 John Deere...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
