Your last generator Maintenance Run
   / Your last generator Maintenance Run #1,091
Dave good call on the refugee.. moved to SC when I was 18.. enjoyed some quality time on Parris Island.. ancient history.. 54 now..
I wanted electric start on a Industrial 14hp Tecumseh OHV motor that I have. Last year I converted it to electric start, it was pretty much just a "bolt on" job.
The motor came off a generator/welder and I'm putting it on a small tractor that I have.
SR
Many older industrial engines still have a lot of hours left in 'em.... nice choice for a small tractor.
I'm trying to not collect any more "projects" till I clean up some "backlog" ;) , but if I came across an olde Wisconsin that didn't look totally trashed, it would probably find shelter in my garage....
Rgds, D.
Had to ask, as plenty of people up here today don't really know much about snow-blower internals....
Knew the name, but had to look it up to be sure...... USMC - thank you for your service to your country.
Rgds, D.
   / Your last generator Maintenance Run #1,095
Thought I'd make a note here about this, Costco has a sale starting June 1 on the Champion 7KW dual fuel generator. It includes a propane regulator with hose & 25' 30A two breaker extension cord. Regular price is $799.99, sale is $549.99 - limit 10. Available in store & on-line while supplies last. We bought one of these a couple of years back (@ a similar sale) & it has worked well for us.
Nick
   / Your last generator Maintenance Run #1,096
Thanks for the "heads-up" Nick.. AWHILE back when someone posted a link to the site that had the 10k duel fuel for around 5-600.00 + free shipping, I hemmed & hawed & lost out.. but at the time my 5250 was runnin things nicely when the power went out.. but I think the run time on the other w/ propane was something like 11-15 hrs on a 20lb bottle, bbq grill size?? HECK, I was only getting 8hrs MAX on a FULL tank of gasoline..
I'll have to check it out.. thanks again..
Nick
Hey, thanks Nick ! That will be of interest to plenty of us.
For those that missed it, Nick posted a dual manifold propane setup in post #1023. Shows as thread page 103 on my screen....
Rgds, D.
   / Your last generator Maintenance Run #1,098
My monthly test was today. I think I have my monthly generator test routine down pretty good now. I use the calendar in my cell phone to remind me to check it every second Sunday of the month
I open the doors, remove the radiator cap, and feed the tube for my antifreeze hydrometer into the radiator to check antifreeze content and level. Next I remove the dipstick to check the oil level which reads almost a quart high but I know I put in the prescribed amount when I did the oil change. After that I connect my load bank and reconnect the bonding strap for the ground. Then I start the engine, holding it in start position until it has oil pressure. Next I look at the meter that I installed for voltage and Hertz to make sure it's reading. After verifying that it starts and runs properly I open both doors and look for any leaks or anything out of the ordinary. Then I close it back up and let the unit warm up. After the gauge indicates the engine is at operating temperature I will apply a small load. I will increase load amounts in progression up to the maximum 52 amps, then back it down to 40 and let it run a couple of hours. Then I remove load in progression until it has none, allowing it to cool, and finally shutting it down. After the test I will open the doors and perform another visual inspection. I finish up by topping off the fuel, disconnecting bonding strap, and load bank. I do not connect the auxiliary fuel system on every test. I may include that every so often.
After getting my machine sorted out it has never failed any of the above tests. Therefore I see no reason to run it for long runs or days at the time for testing.
A very complete and rigorous test - impressive. I agree, once operating temperature is attained, not much is gained going past an hour or 2, unless it relates to a symptom of a recent repair.
With what happened (the alleged excuse anyway.....) sounds like BA airlines could have used you at their data-centre last week ! Too bad you couldn't have run 'em an extension cord :laughing:
Rgds, D.
   / Your last generator Maintenance Run #1,100
Last night, someone hit pole a few miles up the road. Power out for about 4 hours. Have Sams Club Blackmax 8000 watt that is 9 years old. 13hp Honda, I start when needed. Has always started with little to no maintenance, guess I am lucky. I may pull out and run engine with small load a few times per year. Ran everything in home that was needed except heat pump. My spouse has 12,000 BTU in master bed that runs 24 hours a day, 365 days per year due to health issues.
Eddie
Mini Excavator (A55787)
Mini Excavator...
S/N: 1240824 (A55853)
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A53422)
2006 Chevrolet...
