Your last generator Maintenance Run
   / Your last generator Maintenance Run
Sounds about what I'd do (short of high ground-water season(s) here) subh.....
Even non-3rd World (or California) grids will sometimes swing noticeably. Your comment reminded me of (brand escapes me...) pics people have posted of seemingly reliable compact LCD displays you can plug into a 120 outlet, to continuously display voltage.
I have DMMs and a newish ups that will display at the press of a button, but That ^ compact display in a commonly used part of the house seems like a great idea...... Not looking for X decimal place accuracy, just knowing what Normal Voltage "looks" like is a good reflex.....
Rgds, D.
   / Your last generator Maintenance Run #7,702
Average week the power switches off and back on a lot. Storms are
another story. I like to see the V on high demand heat/cooling days.
I also have two Furman AC-215A.
I also have two AC-215A.
Racked, no less; impressive. Thanks for the Model 411.
Too many things need my attention (Squirrel !!!), but probably the reason i haven't picked up one of the cheapy small ones, is some things are built a little too cheap.... not what I really want (from a Safety standpoint. Low accuracy is one thing, letting smoke out, another....). Or.. just forgot to :cool: .
Rgds, D.
   / Your last generator Maintenance Run #7,704
Those two Furman's are built like tanks. The AC-215A is on Amazon for $149 right now. Not a bad price for what you are getting. On sale $120-130 is a good price. My PL-PLUS is old I got it on sale for $230.
Thanks for the price points.... dropped what I could find onto my Amazon.ca list.
215A here is $252 CAD. Only DMC I pulled up here was the
Furman PL-Pro DMC 20 @ $780 CAD.​
I see the 15A DMC in the info table ^, but not pulling a linked product.
The DMC 20 is a bit rich for my blood, but I can see where these fit, even in a mid-range or better home-theatre setup, then obviously recording studios etc.....
Good resilience/survive-ability in sketchy-power land.....
If I suddenly got slightly rich, and decided to build something $$$$ AV wise, these are good options to review, alongside mid-market+ UPS units.....
Rgds, D.
   / Your last generator Maintenance Run #7,706
from amzn ca . Your prices are high. I would have a hard time paying $250-275 for the PL-Plus DMC . I would just buy the AC-215A's. I really like those. The M-8Dx is another option.
8dx here is $315.62 CAD. 9 outlets is nice, and the lights made me smile.... reminded me of having to "borrow" sheet-note lights from the stage-band guys, a few lifetimes ago.....
Those 215A have high-voltage shutdown, and perhaps (?) a more resilient surge suppression network than the 8dx, so I can see where you'd like 'em (esp. considering price point) with "bouncy" power.
Long ago, I could find actual metal-case no-name power bars, with no-suppression onboard.... a nice (/recommended sometimes) way to expand the ports on something like those 215A.
Rgds, D.
   / Your last generator Maintenance Run #7,708
A storm rolled through last night. The lights flickered and I looked over and saw 126v then it dropped to 109v. I flipped the switches and disconnected everything. I was to tired to care that the power went off. Woke up at 05:07 and the power was on. Glad to get the rain.
This is a good example where a quality battery backup system with pass-thru capabilities can save your voltage critical appliances from low & high voltage fluctuations when you’re not there to take corrective action.
If input voltage exceeds set high/low parameters it will automatically correct the output or disconnect from utility and use the battery power to produce 120/240v for your appliances.
I’m not an electronics guy or electrician so I hope this makes sense!
90cummins for
   / Your last generator Maintenance Run #7,709
117 volts as PECO tries to keep up on a very hot and humid day here
one of the high end stereo gurus says to get really good sound you need a power conditioner on the AC line
to your equipment.
2000 Watts for ten grand.
if you want your power clean, really, really clean, guess this is what it costs.
bit of an overspec for 99 percent of us I think
but if I had spent a couple hundred grand on a high end stereo, I wouldn't turn on without one of these.
90cummins for
I was still in college, and first saw the strong utility of pairing diesel gens and batteries while working a Summer job. They were a different scale than yours, as they were targeted for very remote sites in Africa, as essentially prime power. The bigger ones were housed in what looked like a sea-can, but on steroids.
You took a lot of care in building up your domestic system, and it is also reflected in the detailed tests you have posted here. The efficiency of your setup gives you very long run times, on not much fuel. Doesn't get much better than that.....
That some/much of that system is outside your normal work-range, is commendable. (y)
Rgds, D.
SCAN TO RECEIVE TEXT UPDATES (A57192)
SCAN TO RECEIVE...
1994 Generac Olympian 3054 125kVA 3-Phase Diesel Generator (A55851)
1994 Generac...
GMC 2500HD 4wd Service Truck (A55315)
GMC 2500HD 4wd...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2004 Workhorse W22 Motorhome (A53424)
2004 Workhorse W22...
