Your last generator Maintenance Run
   / Your last generator Maintenance Run
Water and ZZZZZ's ...... never good being short on either.
Here's hoping you won't be out long 419 (y)
Rgds, D.
   / Your last generator Maintenance Run #5,602
30 kW whole house generator. Runs a self-diagnostic routine every two weeks and runs for 20 minutes. I check the oil and coolant and that's it.
30 - all electric house, big A/C tonnage, supporting a business/shop as well ? Just nosy 😎 , as a lot of folk seem to "get by" on 22k....
Rgds, D.
   / Your last generator Maintenance Run #5,604
Probably best to call.... I know that many commercial suppliers I deal with up here are short on staff, and are not getting to things as timely as they used to....
That ^, and i know (in my case) some Fleetguard and Baldwin filters are often running behind in the chain, so they'll often come in/go out of a distributor the same or next-day on stock b/o's.....
Rgds, D.
Called and got a computerized reply with an email that does not work. Tried faxing my request. No reply. Think I'll probably just have to get everything locally. At least I have the Wix and NAPA replacements for the oil and fuel filters. Assuming my JD Coolgard II will work for 6 years anyway. Why don't tractor manufacturers do 10 year coolant like is in all our SUV, car and pickups now?
   / Your last generator Maintenance Run #5,605
Getting time to purchase a new cabinet for my standby as the original one is getting rusty. I see Generac is now offering an aluminum enclosure for their earlier steel cabbed units. I'll have to gut the old cab and install everything in the new enclosure. 1900 for a new cab, but cheaper than a new unit.
   / Your last generator Maintenance Run #5,606
Rgds, D.
Thankfully only out for about 4 hours. I was at the gym when the power went out. Picked up a pizza for dinner on the way home since the oven/cook top is electric. Fired generator up around 7:30 and ran it for 2 hours before power came back on. Power company uses the Scotty method of estimating restoration time. Told us 11:30 and it was really 9:30.
Best guess is used a bit over a gallon of gas. That is pretty consistent with the consumption we have seen in longer outages. Between .5 and .7 gal per hour depending on load. If I knew a bad storm was coming I would have the tank full and all jerry cans full giving me about 22 gal of gas on hand. In a real cold snap the furnace runs a lot more than we think it does. So that would last me a couple days if needed. In a more moderate temperature many many days of use out of that fuel.
# years.... good question. One issue might be operating hours (vs. years) - commercial diesels tend to see high operating hours (loaded, and just idling) vs. what a typical light duty gas engine sees.
Hopefully that distributor you were trying is still in business, and just understaffed.....
Rgds, D.
Aluminum should stay clean looking, but at $1900 USD I'd be tempted to build something myself.... says the guy with more projects than time 😎
If you get the new enclosure, please post up some pics !
Rgds, D.
Short outage.... that worked out well.
My big generator would use a similar amount, so I try and keep at least 22 gal on hand (not a fan of crowded gas stations, or long drives to same...). Years ago, I decided that all cans get fuel stabilizer, ALL the time.... cans are tagged, but Stabil etc buys me a little extra time, if I get lazy/sloppy about rotation......
.... I've cleaned carbs and changed floats over the years, but it's not a favourite pastime, and definitely not something I want to be doing during a major outage.....
Rgds, D.
   / Your last generator Maintenance Run #5,610
How much does a wire brush and some paint cost??
SR
New 4x6 Chicken Coop (A50775)
New 4x6 Chicken...
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
40'x20' Steel Carport Shed (A53316)
40'x20' Steel...
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
MD ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
MD ELECTRIC GOLF...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A55851)
2024 Wanco...
