The ambient temperature around the tank plays a big part in a single 20# keeping up in the vaporizing needs. My Toro Groundsmaster 4 cylinder engine runs on one 20# cylinder , some summer mornings I have to avoid the shaded areas while mowing so the sun can make the tank work, in the shaded areas the tank will frost up and the engine slows down until I get back in the sun and the frost turns to water and rpm's return to normal.
part of their 80% increase in electricity costs is being used to pay somebody else to take free power.
geez doesn't sound like good long range planning...can't they just idle a few of the hydro gens? I'm just guessing but there's probably five or six water turbine generators on a big dam, can't they idle a few of them, redirect the water?
Usually when you make lots of power, industry follows.
good thing we only have to worry about dosing our little gens with Sea Foam...
time to change the oil on my big Generac, it's been a year, but seems silly to throw out that perfectly clean oil,
and I still have a hard time seeing the oil level it is so clean, partially I assume due to a good oil filter.
A Generac engine is a clone of a Briggs Vanguard, which I also own. Nice to have parts interchangeability.
I have to believe Briggs makes their engines, (blocks?) and then Generac relabels. I never thought Generac built engines,
despite their ads as to the durability of their engines. Does anyone know?
The 22kw Generac even comes with an oil drain hose, though I'm not sure the last bit of oil drains out due to the angle of the hose.
Lost power last night for 4 hours and finally had a chance to actually use my 4kw battery backup system to power the house.
There's nothing like a real outage to appreciate and see how a system works.
When it's dark out and the winds blowing & raining with tornado warnings the wife paid attention to what I was showing her.
My 4kw system is enough to allow use of all circuits except the dryer.
Still as with a small generator I monitor the wattage draw on the system with the system monitor.
With all essential household appliances TV, heat & lights being used I was around 400 watts max load which I could sustain for several hours or more.
It was nice to throw a switch rather than pull the generator out start and run cords.
Generators were running up & down the street making quite a lot of noise but I was silent.
90cummins
yes generac builds their own engines complete including valves and alternators. They produce their own windings. The engine is basically the vangard.part of their 80% increase in electricity costs is being used to pay somebody else to take free power.
How do you best check for voltage under load?ran my Champion 3100 inverter gen for about half an hour today pulling 2400 watts, a good workout for it.
It did fine, though I forgot to check the voltage under load. Really don't trust their little green LED.
I would have used a cheap multimeter I have, plugged into open receptacle, at no load and full load. The gen got substantially louder under full load; what was surprisingly quiet at idle, and particularly on the lower rpm idle setting.
But as load was increased, the exhaust got louder. Not sure I'd want that next to my rv all night but if the juice went out, I'd use it for sure. This is my portable backup unit in case I want to dry camp with my travel trailer or if the main gen conks out, which is pretty unlikely. Just my version of belt and suspenders. I have a sound level meter from Radio Shack (I owned a Radio Shack franchise for five years a long time ago and took some fun stuff home with me...) so I could actually run a noise level test next time.
These inverter gens are made to be quiet, and in this Champion's case it means hiding the oil fill area behind a plastic door. Does not make checking oil easier for sure...good thing it has a low oil level shut down. I did notice some new burning smells after half an hour at full load; to be expected as paint burns off. As long as the plastic case doesn't start to melt...![]()
Hey just thinking this might be a good place to remind folks to power up their outboard boat motor if it isn't used regularly too!. I am getting in the habit when I fire up the generator too. During the winter I look for an opportune weather day. I kind of enjoy hearing my Merc sitting in a bucket purr! Makes me think of summer and warmer sunny weather! :fishing:
Yes good point. I make sure I run it good and warm. Cycle the fwd/rev a few times and turn up and hold the throttle.I would discourage running it (or any motor/vehicle of value) unless you can actually warm it up.
Condensation from a brief run can cause rust in cylinders.
In cars it can cause the exhaust system to rot from the inside/out.
