Your last generator Maintenance Run
   / Your last generator Maintenance Run #21
From a chainsaw website I learned that one should always use high test gas in small engines as high test contains the least alcohol. The site even had a link to alcohol free database by region.
The alcohol deteriorates rubber fuel lines and rubber seals.
Since most gen-sets are Chicom based the seals and lines are probably rubber based I would always use pure or hi-test.
If your fuel line is puffy and soft it is probably rubber and should be replaced B4 particles clog the carburetor.
Owner's manuals on newer chainsaws state "Always use HiTest gas"
   / Your last generator Maintenance Run #22
   / Your last generator Maintenance Run #23
Man! I can't believe any manufacturer would use rubber parts.Neoprene,yes,maybe,but rubber? I hope not! Another thing on that octane,you know,companies sometimes use ethanol to give them a point more on octane.Of course,it's not worth the trouble ethanol can cause in general. don-ohio :)^)
Can you explain to a plain ol' country boy what "a step inductive load is"? :)
1) Mostly just semi-tired geekspeak :cowboy: ..... I should have said stepped, as in sudden load transition.
Technically (good question, BTW), upon reflection, it is not that easy to connect a household item to a genny that does not present as a stepped (as in sudden transition) load. I know incandescent bulbs have a higher starting current (filament warmup) than running, and expect the same current pattern with a resistance element on an electric heater. Quartz tubes heaters; not sure.
2) What I should have expressed more clearly is that an electric motor (common household example of an inductive load) gives you a lot of bang for your buck as a test load. If you look at charts (typically found in a decent generators owners manual) that show Starting Watts vs. Running Watts for motors, you get a pretty good idea of how much more current a good sized electric motor draws at startup. We've all been around a shop when a heavy elec. compressor starts, you'll often get a dip in the lighting, even with the shop wiring in reasonable shape.
As a contrast, think of testing a 5kw genny, by plugging in a few lights. Common (except for work flloods) lights around home don't draw much more than 100w today, most not even close. Space heaters are good, but household ones max out about 1.5kw, and may not be that common where you live. By slowly adding smaller loads, you can work up to loading a gen to 50% or more of max load - a valuable test on it's own.
A sizable load, with a fast transition (ie. stepped ;) ) may highlight the early stages of a problem with a generator, where a slowly-added-equivalent-load may not. A poor electrical connection, or even a just-starting-to-seize-up mechanical regulator may be readily found once you fire up a good sized electrical motor (circular saw, etc).
I'm often too verbose (aka Ramble on Too Much :laughing:), but in this case, perhaps not !
Naahhh, let's be honest, it's probably just my ancestral Scottish blood kicking in...... I want to put my generator to work even as a Maintenance Run task, so vacuuming a vehicle seemed like a good use of gasoline - that, and I can't afford the daytime electricity rates so I'm getting tired of vacuuming in the dark ! :laughing:
Rgds, D.
I have a very old 8HP 3500 approx. watt generator and as long as I run the Marathon gas with no ethanol:thumbsup:,I never have a problem even up to a year's storage.
Of course,I keep it in the basement,not out in the cold,which DOES make a difference.
Funny thing,a coupla' years ago, it WOULDN'T start.:mad:Finally found the culprit.......a shorted kill/on switch. New switch,no problems.
I always run a generator slightly overfilled on good synthetic oil. More generators have bitten the dust because of low oil than any other cause,it seems to me. don-ohio :)^)
Good practices Don, I do most of the same. My new gen has low oil shutdown, but I always check anyway - real shame to lose a motor over half a quart of oil.
Rgds, D.
   / Your last generator Maintenance Run #26
Thanks for the reminder!
I was getting things ready for this winter and the generator(onan 6500watt) wouldn't start. Found a fuse buried inside that was open, not sure what it went to but it started after replacing it. I've been told by a guy that used to work for public utility district that they would rent loads to run the generators with. He said they had blowers on them because they would get so hot. He said something about loading over 100% rated output for a specific period of time or the generator would "learn" to only put out what was the last highest load. I have to admit that i may have some of this wrong, but he sure seemed to know what he was talking about, whatever that was. :laughing:
   / Your last generator Maintenance Run #27
Yep,Dave!I tried to tell my kids that oil is the lifeblood of an engine and coolant is its sweat.LOL! don-ohio
You're welcome ! I'm using log notes, and getting better about this, but wanted this thread as a public nudge (to me) to stay on track.
That might have been a magnetization issue on a big gen, would need to know the exact model, and get somebody online here that knows big gens well (ie. not me :) ).
One poster on here uses his actual house backup loads for testing - probably the most practical/relevant way to do it at home.
If that fuse that went on you is the inline old-school glass type (as opposed to the modern plastic automotive blade fuses), it is a good idea to check what the factory rating on the Voltage of the fuse is.
120VAC glass inline fuses tend to have a higher (relatively speaking, it takes a good ohmmeter to see the difference) resistance than a DC glass fuse (typically 32vdc rated, for example), at the same current rating.
120VAC glass fuses (at the correct current rating) will often appear to work OK in a low voltage application, but in a control loop, you may be introducing a voltage drop across the fuse that can give some equipment intermittent problems.
Yeah.... I got that Tshirt the hard way.... :cool:
Great discussion here... yesterday had me thinking that on-board generators in gasoline engined RVs probably have the roughest life. Few people are going to consistently treat (if at all) RV tank loads of gas with additives, and especially if the RV is mainly used at hookup sites, then these on-board gens will be spending a very long time sitting around with old ethanol gas in 'em.
I can see that keeping the RV dealers busy....
Rgds, D.
Glad to hear they are being taught, and are hopefully listening.
Many don't , esp. when their parents just buy 'em a new whatever-they-destroyed-last. (I don't blame the kids, in this scenario).
Rgds, D.
   / Your last generator Maintenance Run #30
The best maintenance I have done in the last year was finding a "Fast Track" near me that has non ethanol gas for all my small engines.
Wish I had that option. I start my gen every 2-4 weeks and put a small load on it. It's fairly new so only one oil change thus far. I will drain the gas from time to time and refill with fresh gas and I use Seafoam in all engines that do sit for a while.
   / Your last generator Maintenance Run #31
Rgds, D.
Thank you Sir for the detailed response :thumbsup:
   / Your last generator Maintenance Run #33
I got mine out in anticipation of a winter storm a few weeks ago. Started after about 6 pulls.
I have 100% gas (92 octane) in it from this summer, with some seafoam if i remember right...may have to add a few more ounces just to be sure!!
   / Your last generator Maintenance Run #34
I wish I could get ethanol free gas. Not sure it's worth the 100 mile trip one way to get 40 gallons?
Clem - even though I'm buying what I believe to be ethanol free HiTest, I too treat my fuel. I'm kind of that way anyway, but esp. with something like a generator I'm more than fine spending my limited money on a Belt+Suspenders approach.
Rgds, D.
There's your time of course, but I'd run the travel #'s as..... 20mpg vehicle, 5 gallons each way - call that $40 in fuel for the travel vehicle. If I had the time, I'd be inclined to make it a roadtrip, and chalk that $40+lunch up to preventative maintenance on your small engines. Unless you are a commercial contractor, that 40 gallons should hold you for a while.
Just my obsolete Canadian :2cents:
Rgds, D.
   / Your last generator Maintenance Run #37
If I did that should the gas be good for a whole year if treated? Ethanol free gas that is.
IMO, with a good fuel stabilizer added to Efree gas, yes 1 year is doable. Assumes well sealed gas cans too (meaning any approved can in decent shape, no cracked vent caps....).
Stabil used to quote 2 years at their double dose rate, and Startron does too, but I'm not clear on the dosage rate they mean for 2 years. I think it's Soundguy (or is it Diamondpilot... there's that memory of mine again....) that's a fan of Stabil's Blue (or better ? I think they have another grade now ?) Marine grade gas stabilizer.
These days I've been running Startron all the time, with also Stabil Red for anything that will sit for more than a month. I'll probably upgrade to Stabil Marine the next time I buy a bottle.
Esp. if this is your 1 year's worth of Backing up the Homestead Power fuel cache, I'd test a small amount of the fuel for ethanol at the station, before loading up 40 gallons worth. There are some commercial test kits available I think (don't know how fast they work, never used one) - Chris or another pilot on here may know - Don has posted his DIY test in a glass jar (absorbs water, for a volume increase I think) - he could let you know how fast that works.
I'd also make the buy at a good Name Brand station, hoping for better quality Efree gas than at Joe's - Eat Here and Get Gas stand.
Rgds, D.
Found this file on the Stabil site.
http://www.goldeagle.com/UserFiles/file/Ethanol%20411/Changes_in_Gasoline_Manual_IV_Updated_Logo.pdf
(Was trying to post the pdf file here, but seems like the Upload Manager doesn't accept anything > 1Meg).
Possibly more than you want to know, about gasoline/gasohol.
Page 24 (or 26, depending on how you count) describes testing for the presence of ethanol. Figure 4-6 can be used to interpret % ethanol levels from the test.
Just in case.... anybody is having trouble getting to sleep tonight..... :zzz: :zzz: :zzz:
Rgds, D.
A fun Spring around here - an ice storm took down a line 4 concessions north of me last week - my buddy was w/o power for a while that day. Reminded me to get back to this.....
Rgds, D.
Date: Apr 14/13
Generator: 7kw Briggs
Activity: 5gal Shop Vac - cleaned Civic
Final Fueling notes: filled w. NonE gas, Stabil and Starton added.
Maintenance notes (Done, or Required): Fix up the second work flood light, and add both for next run. Electric start used this time.
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
Mower deck storage axles
Mower deck storage...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
