You need balast or you will trash your front axle!!!! really?
   / You need balast or you will trash your front axle!!!! really? #91
It was a ~2' by 3' by 2.5' ish chunk of concrete with chunks of steel and granite rocks in it which weighs 2000# per our truck scale. It is mounted on a set of 3 point forks.
It might have been more than 5' back, but I don't think the center was more than 7' back.
I will see if I can get more specifics tomorrow.
The wheelbase is 86.6" per TractorData.com LS P7010 tractor information
Aaron Z
Correction, its a 2x2x3 chunk of concrete with granite rocks and scrap steel in it.
Its centerline is 4' back from the center of the rear axle.
The "center of mass" for the Snowwing (middle of the blade) is 6' in front of the front axle.
I remember being pleasantly surprised that it too more than its own weight off of the front axle.
Aaron Z
   / You need balast or you will trash your front axle!!!! really? #92
No guessing. The math is the math. No theory, just proven mathematical facts.
We had a big discussion on this last summer? With oversized and he did not believe it about ballast until he did a real test on the scales. Now he is a believer.
No. Its wrong because we a re not talking a static condition. Enuf has been said about the greater front loading possible with rear ballast that it should have been called to your attention as obvious. If you use your loader lightly, counterweight will reduce front load. If you use your loader to capacity pushing and lifting, then rear ballast and counterweight will enable much more weight on the front axle -- up to the combined weight of the entire tractor, its ballast and counterweight, and the load supported on the loader. The tractor will move but not travel in this condition because the rear wheels are skimming and you cant steer. If you use the loader a little lighter duty youre able to steer and travel as needed with about 90% of all combined weight on the front axle.
What in what I said is wrong?
Im not sure you actually said it, but wrong would be any implication that counterweight would spare the front axle if you were really using a TL anywhere near its limit. If babying it; like just carrying stuf around in the bucket, you could find counterweight that would lessen the load on the front axle under specific circumstance, but those weights are trivial compared to the front weights you will encounter with those same counterweights in push/lift scenarios.
,,,,,I cannot believe there was ever any doubt that weight behind the rear axle lightens the front under static/light/predictable conditions. [Incredulous Icon]
   / You need balast or you will trash your front axle!!!! really? #93
No one has mentioned the angular weight shifts due to the position of the fel due to the lift cylinder's mounting position on the tractor.
The bottom of the lift cylinder is anchored to the tractor at a point somewhere between the front axle and the rear axle. A good portion of the weight of the load is focused at this point.
This makes the load in the fel actually put more weight on the rear of the tractor since the anchor point is behind the front axle. So the more you load the fel, the heavier the REAR of the tractor gets, which according to the modelling here, makes the front get lighter!
So the heavier you load the bucket, the lighter the front end gets !
Don't overload the bucket as the front wheels might come off the ground.:)
Ain't physics fun?
   / You need balast or you will trash your front axle!!!! really? #94
Ain't physics fun?
Please take another look at this diagram
   / You need balast or you will trash your front axle!!!! really? #95
This is quite interesting to me.
3pt balast takes some weight off the front axle when unloaded/lightly loaded....
BUT...
The added lift capacity that ballast gives the loader will likely result in a higher cumulative stress on the front axle as heavy loads can be regularly placed on the loader!
   / You need balast or you will trash your front axle!!!! really? #96
No one was mentioning going to the limit when we first were talking about this. My post was for James talking about a old thread when you had to butt in. Why you dogging me?
   / You need balast or you will trash your front axle!!!! really? #97
This may need to be refined but...
   / You need balast or you will trash your front axle!!!! really? #98
But 4570 in his second example skillfully demonstrated that movement was needed . . But that great force was required to create slight but important movement . . thus altering ground pressure . . a term never used until much much later after 4570's communications.
Just so no one misses my response to your posted question ive repeated it again here: "You asked if i am now understanding . . and my answer is yes . . because someone properly showed there was movement of the lever because ground "contact" is a variable. "
If you still think movement is required, or that 4570's example showed movement or proved movement, then you're still not getting it and you're still wrong (or unable to admit you're wrong). I vote we move on and stop the nonsense. You derail way too many threads with these types of tangents.
It's OK to be wrong -- I am wrong all the time. But it's important to recognize when you're wrong and/or when others are right. I think that's maybe more important than being right in the first place.
   / You need balast or you will trash your front axle!!!! really? #99
BUT...
Bingo!! :thumbsup:
(though I would of ended your first sentence after the word "axle".)
   / You need balast or you will trash your front axle!!!! really? #100
Few things that need to be mentioned here:
1: Gladehound (plus any others that might be in this thinking) Having loaded tires while very useful for adding weight/traction that then means you can carry/lift more with the loader DOES mean that when you carry/lift more you are also subjecting your front axle to more weight/stress thereby potentially increasing the chances of axle failure sooner. Why is this so? Look at that great diagram posted earlier (Koua just posted it again post number 94) by adding weight to the rear tires you're only effecting the front fulcrum which allows the tractor to lift more without the rear end coming off the ground. (Potentially if you can get enough weight into your tires you could max the lift capacity of the loader and still keep the rears on the ground. Sorry I'm too lazy to draw this out but hopefully if you look at that diagram you'll understand.) So if the front axle is the only fulcrum affected then when using the loader it gets the additional weight applied down thru it.
...So that is an additional reason why when using the loader the best place to have additional weight is behind the tractor - a counterweight on the 3pth. I hope this helps as I noted by your posting and your picture that you don't use a real counterweight that's hung behind the tractor far enough to be of much effect.
You're asking about damage or potential damage to the front axle - yes you're making your tractor useful by weighting your tires but you're not helping your front axle. use a counterweight and you'll both make your tractor useful and add to the longevity of your front axle.
...now I had a couple other points but I forgot what those were. lol! Till next time if I remember.
E.
2022 New Holland C327 Compact Track Loader (A56435)
2022 New Holland...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52707)
(INOP) 2016...
Entyre Chip Spreader (A57453)
Entyre Chip...
2021 Caterpillar 272D3XE Compact Wheel Loader Skid Steer (A55973)
2021 Caterpillar...
TANK SEEDER (A58214)
