YN 240 D head bolts
   / YN 240 D head bolts #1
davecharles
Carbondale IL
Yanmar 2220D Yanmar 240D
I'm putting together the engine on my YM240 d (came to me in a box) and I've encountered another problem. The head bolts (studs). All 6 are the same size but it appears that the one in the intake should be much shorter. Is there a spacer missing or did someone put in the wrong stud. The hardened studs are M15X1.5. The one I need looks like it should be about 75mm long or a 60mm bolt would do. I have emailed Fredericks and Schaeffers and called Hoye. So far no luck. Now I'm looking for suggestions. Anyone out there have the short stud or bolt or know where to get one?
Dave
   / YN 240 D head bolts #2
If you know the sizes you need.. Try to google them. I assume they are grade 8 ? If there is a specialty nut and bolt place near you, try them Fastenal is 1 that is located here
   / YN 240 D head bolts #3
What does "no luck " mean? What happened when you called Hoye?
Hoye said they don't have the bolt or stud. Fredericks and Schaeffers have not replied yet. Fastenal said they do not have any 15 mm diameter bolts or studs. I don't have a parts breakdown so I have no part number or picture of the assembly.
   / YN 240 D head bolts #5
Hoye doesn't show a part # for that head stud inside the manifold, but here's their parts diagram. Did you end up with a spare short stud that looks like this?
Also - note the left front stud is longer than the others, to leave threads above the nut. The support coming back from the radiator goes onto that extra height then is secured with a second nut.
Yanmar Tractor Parts: BLOCK
Right now I have 6 studs that appear to be the same length. No short stud (part #5)
Dave
   / YN 240 D head bolts #7
   / YN 240 D head bolts #8
Any supply house, (McMaster-Carr), should have what you need.
Thanks Normnde, I checked McMaster Carr and they show no results for m15 x 1.5 size bolts or studs. Any other good ideas?
   / YN 240 D head bolts #10
Are you sure of that size? I don't find any supply house that carries it.
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
New/Unused Bastone Portable Toilet (A51573)
New/Unused Bastone...
2005 KENWORTH T800 (A52472)
2005 KENWORTH T800...
New Long Forks (A53002)
New Long Forks...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
