YM336 stopped moving when I shifted the power shift lever
   / YM336 stopped moving when I shifted the power shift lever #1
yukolix
Whitehorse, Yukon, Canada
Yanmar 336D
My tractor suddenly stopped moving today when I shifted the power shift lever from 2 to 3 (w/o clutching). It stopped moving and it made a horrible grinding noise. Disengaging the clutch makes the noise stop. I pushed the power shift lever to 2, 1, neutral, changed range etc the tractor wouldn't move and the noise is there as soon as I engage the clutch. I can move the power and range shift levers freely, the transmission oil level is full. I changed the transmission oil and hydraulic filter and cleaned the suction screen about 30hrs ago. I was harrowing a sandy area with 4 diamond harrows when it happened. I own the YM336D for about 5 years and have put on 200 hrs (it has 950hrs total) moving snow, haying about 15 acres each year and moving some dirt.
There is no Yanmar dealer here. I've fixed my share of tractors but I'm new to Yanmar and I'm looking for hints. Has anyone had this happen to them?
Thanks,
Felix
   / YM336 stopped moving when I shifted the power shift lever #2
You probably stripped the spline coupler where the clutch shaft attaches to the trans.(if you are lucky)
You will have to split the tractor to replace it.If you are in high range,and shift from 2 to 3,it just slams in gear,and I always use the clutch,and let off the throttle. I don't care what they say,something is going to break if it slams into gear.
Thanks for the reply. It sounds like something might be stripped.
Thanks! I downloaded the parts manual, very helpful.
I split the tractor and the coupler is stripped. So I guess I'm lucky. Got to get the parts now. But first I want to check clutch wear etc.
   / YM336 stopped moving when I shifted the power shift lever #7
Glad to hear its that piece and not something serious! Barry nailed that one nice contribution sir! :thumbsup:
I finally got the parts and found time to put everything back together. the tractor is as good as new. I installed an new coupler, disc and throughout bearing. Thanks for all your tips and help it's much appreciated.
   / YM336 stopped moving when I shifted the power shift lever #9
Have problems with yanmar ym 336d power shift slipping in 2 & 3 power shift. Check transmission oil pressure cold reverse & 1 216 psi 2nd 116, 3rd 90 psi 1500 rpm as tractor warms up reverse &1 211 psi, 2 nd , 82 psi, 3 rd, 65 psi, need help to solve problem mike @ mike,melenka@rjvnet,ca
   / YM336 stopped moving when I shifted the power shift lever #10
Have you replaced or changed the hydraulic filter? The filter is like a long tube with an olefin membrane. Usually, it's found at the rear of the tractor with a 3 bolt pattern cover. Make sure to have at least a 8-gallon or more bucket under there. Clean the area around it too before starting. NEVER back flush the olefin membrane filter, doing so will destroy it. If you have a fine mesh strainer, strain the oil and use again. Drive a little while and repeat to take out the inside nasty shavings and junk. Look at the Hoye tips and helps down the left column about this filter too.
Also, if the above did not work, you may need to get a new hydraulic pump. Others here who have been through this could chime in on this topic.
23222 (A50323)
23222 (A50323)
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
LOT NUMBER 250 (A53084)
LOT NUMBER 250...
2002 WESTERN STAR 4900 EX TANDEM AXLE SLEEPER TRUCK (A52577)
2002 WESTERN STAR...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
