YM336 stopped moving when I shifted the power shift lever
   / YM336 stopped moving when I shifted the power shift lever #1
yukolix
Whitehorse, Yukon, Canada
Yanmar 336D
My tractor suddenly stopped moving today when I shifted the power shift lever from 2 to 3 (w/o clutching). It stopped moving and it made a horrible grinding noise. Disengaging the clutch makes the noise stop. I pushed the power shift lever to 2, 1, neutral, changed range etc the tractor wouldn't move and the noise is there as soon as I engage the clutch. I can move the power and range shift levers freely, the transmission oil level is full. I changed the transmission oil and hydraulic filter and cleaned the suction screen about 30hrs ago. I was harrowing a sandy area with 4 diamond harrows when it happened. I own the YM336D for about 5 years and have put on 200 hrs (it has 950hrs total) moving snow, haying about 15 acres each year and moving some dirt.
There is no Yanmar dealer here. I've fixed my share of tractors but I'm new to Yanmar and I'm looking for hints. Has anyone had this happen to them?
Thanks,
Felix
   / YM336 stopped moving when I shifted the power shift lever #2
You probably stripped the spline coupler where the clutch shaft attaches to the trans.(if you are lucky)
You will have to split the tractor to replace it.If you are in high range,and shift from 2 to 3,it just slams in gear,and I always use the clutch,and let off the throttle. I don't care what they say,something is going to break if it slams into gear.
Thanks for the reply. It sounds like something might be stripped.
Thanks! I downloaded the parts manual, very helpful.
I split the tractor and the coupler is stripped. So I guess I'm lucky. Got to get the parts now. But first I want to check clutch wear etc.
   / YM336 stopped moving when I shifted the power shift lever #7
Glad to hear its that piece and not something serious! Barry nailed that one nice contribution sir! :thumbsup:
I finally got the parts and found time to put everything back together. the tractor is as good as new. I installed an new coupler, disc and throughout bearing. Thanks for all your tips and help it's much appreciated.
   / YM336 stopped moving when I shifted the power shift lever #9
Have problems with yanmar ym 336d power shift slipping in 2 & 3 power shift. Check transmission oil pressure cold reverse & 1 216 psi 2nd 116, 3rd 90 psi 1500 rpm as tractor warms up reverse &1 211 psi, 2 nd , 82 psi, 3 rd, 65 psi, need help to solve problem mike @ mike,melenka@rjvnet,ca
   / YM336 stopped moving when I shifted the power shift lever #10
Have you replaced or changed the hydraulic filter? The filter is like a long tube with an olefin membrane. Usually, it's found at the rear of the tractor with a 3 bolt pattern cover. Make sure to have at least a 8-gallon or more bucket under there. Clean the area around it too before starting. NEVER back flush the olefin membrane filter, doing so will destroy it. If you have a fine mesh strainer, strain the oil and use again. Drive a little while and repeat to take out the inside nasty shavings and junk. Look at the Hoye tips and helps down the left column about this filter too.
Also, if the above did not work, you may need to get a new hydraulic pump. Others here who have been through this could chime in on this topic.
   / YM336 stopped moving when I shifted the power shift lever #11
   / YM336 stopped moving when I shifted the power shift lever #12
Have checked filter, it's clean, changed oil, if it is the pump why is pressures in first and reverse ok ?
   / YM336 stopped moving when I shifted the power shift lever #13
I believe this came up before. Yrs..... ago. And the problem was in the valve body. Fredricks calls it the, Power Shift Cover (Regulator) and Gasket. A pic of it is on p.124 Trans. It needed cleaned and a couple Valves in it was rusty. Worth checking into.
   / YM336 stopped moving when I shifted the power shift lever #14
Thanks, I have seen a photo where gasket was broken causing this problem, waiting for manual before I take it apart, thanks for the input I want to do easy stuff first before having to split tractor.
   / YM336 stopped moving when I shifted the power shift lever #15
Don't blame you. The Manual will be a big help. I don't think your going to need to split it to get to it. Maybe wrong but I don't think I am.
   / YM336 stopped moving when I shifted the power shift lever #16
Even with a parts manual, those exploded assembly diagrams are worth reviewing too. Wonder if Winston has that area for your model?
OH yeah, I remember now, the YM336 is the aka YM3110 or John Deere JD950. There is a place to get that info right now.
CASE 610 Sprayer System 2000 Gallons (A61307)
CASE 610 Sprayer...
GIYI RB66-66" ROCK BUCKET (A60430)
GIYI RB66-66" ROCK...
2012 HYUNDAI  HL740-9 WHEEL LOADER (A58214)
2012 HYUNDAI...
UNUSED FUTURE FT13 EXCAVATOR (A60430)
UNUSED FUTURE FT13...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
