bmaverick
Super Member
- Joined
- Sep 17, 2013
- Messages
- 6,765
- Location
- Beloit-WI
- Tractor
- Yanmar YM2610 ■YANMAR GURU■ EXTRAORDINAIRE
Have problems with yanmar ym 336d power shift slipping in 2 & 3 power shift. Check transmission oil pressure cold reverse & 1 216 psi 2nd 116, 3rd 90 psi 1500 rpm as tractor warms up reverse &1 211 psi, 2 nd , 82 psi, 3 rd, 65 psi, need help to solve problem mike @ mike,melenka@rjvnet,ca
Have you replaced or changed the hydraulic filter? The filter is like a long tube with an olefin membrane. Usually, it's found at the rear of the tractor with a 3 bolt pattern cover. Make sure to have at least a 8-gallon or more bucket under there. Clean the area around it too before starting. NEVER back flush the olefin membrane filter, doing so will destroy it. If you have a fine mesh strainer, strain the oil and use again. Drive a little while and repeat to take out the inside nasty shavings and junk. Look at the Hoye tips and helps down the left column about this filter too.
Also, if the above did not work, you may need to get a new hydraulic pump. Others here who have been through this could chime in on this topic.
