Oil & Fuel YM2500 Pushing Coolant Out the Radiator
   / YM2500 Pushing Coolant Out the Radiator #81
Somebody been in it long ago from the looks. The Pin in the throttle shaft isn't even Seated back. After the Refurb paint. This is getting interesting.
Getting the throttle shaft fixed and PTO seal & wear collar replaced should be the end of the repairs.
Fredricks Emailed me back today. They are getting the parts ready to be shipped out to me.
I don’t have the tools, or the knowledge to fix it myself. My local tractor repair shop will be doing the repairs. It’s the same shop that replaced the front timing cover. They emailed me an estimate today and I forwarded it to Fredricks.
Have a Blessed Day!
Travis
***UPDATE 07-08-2025 Tuesday***
I finally got to work the tractor and use the PTO over the weekend.
There’s good news and bad news. Although this tractor has been a nightmare, I do have some peace of mind.
Good news is it isn’t leaking oil from around the PTO Shaft/Seal like I originally thought.
I was also able to drop the tractor off yesterday to my local tractor repair shop to get the Throttle Shaft Assembly Repaired/Replaced.
Bad news is there’s a couple coolant leaks coming from between the cylinder head and engine block, on the right side of the engine in the front and in the back where the head bolts to the block. It isn’t much, but you can see it if you look for it. I had to add coolant after bush hogging.
Good news is Fredricks has approved to have the engine tore down at my local tractor repair shop and see if there’s a head gasket failure and to see what’s going on.
   / YM2500 Pushing Coolant Out the Radiator #84
It's going to be interesting after the shop pulls the head. I believe to see a big problem with the Eng. Block. It's there could Head also. They know it!!
   / YM2500 Pushing Coolant Out the Radiator #85
I'm glad that you have a great shop nearby. I'm sorry but to me photos 1 & 4 look like a cracked block from here. I will hope that looks are deceiving.
Good luck.
All the best,
Peter
Good luck.
All the best,
Peter
I don’t believe the block is cracked, but we won’t know anything until the head gets removed.
I sure hope there isn’t a problem with the block.
   / YM2500 Pushing Coolant Out the Radiator #88
There's potential problems and you can see it in the Pic.s if you know what to look for. The Eng. Head not all that big of a deal to replace. The possible Eng. block damage is going to be the big issue. Crack, Rust Etc.. Parts are not going to be that bad of a problem either. It's just what's involved correcting it. The good thing It's A JD. model. Same Eng. as the 850 I believe. ;)
   / YM2500 Pushing Coolant Out the Radiator #89
Can you elaborate?
Thanks.
All the best, Peter
   / YM2500 Pushing Coolant Out the Radiator #90
About what you don't understand. Elaborate Please?
Pickup Truck (A59230)
UNUSED FUTURE 24" HYD MINI TILTING BUCKET (A58376)
UNUSED FUTURE 24"...
3410 (A47477)
3410 (A47477)
2016 Kubota MX5200 (A57148)
2016 Kubota MX5200...
1999 CLEMENT END DUMP (A58214)
1999 CLEMENT END...
2025 STB47 Telescopic Boom Skid Steer Attachment (A56857)
2025 STB47...
