YM2310 transmission question
/ YM2310 transmission question #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
A few days ago I bought my first Yanmar tractor. The shifter pattern shows 1 through 4 but it also has a "C" gear listed. I can't seem to get it to go into this C gear. Anyone know what it is?
Thanks,
Eric
/ YM2310 transmission question #2
C is creeper... lower than 1st.... shift into 1st and keep pushing forward to creeper
/ YM2310 transmission question #3
My YM2002D also has a creeper range. Mine has a 10mm hex pun which blocks it going into creeper mode. I have removed it to check it out. In high gear in creeper, a person can easily out walk the tractor speed.
In practical application, I have never found a use for the creeper range gears. Range 1 gear 1 has more than enough torque and is slow enough for any activity that I have ever needed. This includes tilling ground that had never been tilled and pulling several vehicles out of ditches, mud, snow.
Thanks for the replies folks. I'll try getting it into creeper gear today just to see how slow it goes.
Eric
/ YM2310 transmission question #6
You will just need to pull that little knob straight up in order to move the shifter into the C range. As others have mentioned it is EXTREMELY slow.
/ YM2310 transmission question #7
Fwiw... on my 2210d... I used creeper in a totally unsafe manner...
I would back up to my brush hog, set the parking brake, get off, and use creeper and power shift to line up... Worked great but not recommend of course
At full throttle it would go 0.3 mph at idle probably 0.05 mph.... you could get run over but it would take a loooong time lol
I saw that knob and knew it had some purpose. I'm gonna try it out tonight.
Thanks,
Eric
/ YM2310 transmission question #9
Am I the ONLY ONE who uses CREEPER gear?
When putting up fencing, I use the fence puller before clipping or tack-nailing the woven fence to tees or posts. Creeper gear is the ONLY way to go to ensure the fence is aligned, pulled and not over stretched.
I've gotten my Post hole auger stuck in a hole really deep (4FT) in rock. Had to use creeper gear to help rock the auger out of the hole.
Son's car hit the back end of a truck. Not a scratch on the truck whatsoever, but his front fascia and the upper rail over the radiator was caved in. Creeper gear to the rescue!
Creeper works well pulling out stumps too.
/ YM2310 transmission question #10
Notice that my statement was an “I” statement.
That does not imply others may not find a use for it.
That you have found uses for creeper speeds is great, thanks for the info others may find helpful.
/ YM2310 transmission question #11
Coy, my posting wasn't totally directed at you, your post was the closest to string off of for a reply. I could of picked on Winston's post too. LOL ;)
I know there were other uses I had found with the creeper gear. One was when the tractor was on a sheet of ice, couldn't move any direction. It just spun the wheels. I learned that it was way worse the faster the wheels spun. I then had the inkling to drop it as low as it would go, creeper in 3rd high. Immediately, the tractor moved off that ice zone.
Another time was pulling out a huge tree stump. It was dug out, but it wouldn't totally come out. Put the tractor in creeper and my sons got under the stump to hack off the huge tap root. Creeper really brought that sump up so far to give them access. It was in like not going anywhere, but as the tap root was getting sawed/chopped, it gently snapped and pulling it out was EZ. My boys were even rocking the stump. So, for safety, creeper came in real handy.
/ YM2310 transmission question #12
I wonder if gearing that low risks stripping the ring and pinion in the differential from extraordinary torque, when its used with good traction.
/ YM2310 transmission question #13
No more so in my opinion that 1st range 1st gear. Movement in creeper 3rd gear (my tranny is a 3 speed with 4 ranges including creeper) so slow that I doubt you could strip the ring and pinion, but I guess anything is possible.
Again I have never found creeper useful over using 1st range and 1st gear that is already terribly slow. Mine has a pin that must be removed to go into creeper range and while it only takes a few minutes, it just provides so little to any task I have had that it isn’t worth the effort on my tractor. Different models may be different. In fact I rarely use 1st range and 1st gear.
/ YM2310 transmission question #14
Creeper gear is good for pulling a manual trencher that is not self propelled. I also used it to move a 12' x 20' shed across the yard.
/ YM2310 transmission question #15
I have to do a 10 x 20 shortly, how well did she pull on flat ground and did you empty the shed.
/ YM2310 transmission question #17
Or a series of pipes as rollers. Anything that reduces the fiction is your friend.
All the best,
Peter
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2019 P.J. Trailer Trailer, VIN # 4P5F82029K1307542 (A65563)
2019 P.J. Trailer...
Dexter trailer axles (A61567)
Dexter trailer...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
2005 John Deere 7320 (A60462)
2005 John Deere...
