YM2310 clutch dragging
/ YM2310 clutch dragging #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Greetings All,
I just bought YM2310 tractor and the clutch drags. The clutch was stuck when I bought it but I was able to get it to slip when the tractor is in high gear. Now the clutch only works when I am using the tractor in third or fourth. I have adjusted the clutch according to the manual. I can tell that the clutch is not releasing completely. When I let the clutch out in third or fourth gear it grabs right away, I cannot feather the clutch. Should I just drive this tractor around with the clutch pedal depressed and let the clutch slip? Maybe that would wear away any rust. Or maybe the clutch disc itself is swollen and must be replaced. Any advice greatly appreciated.
Thanks,
Eric
/ YM2310 clutch dragging #2
Only an opinion. I think you will end up splitting it to correct the problem. I would split, then order parts needed. Not understanding why clutch works in 3rd and 4th and not in 1st and 2nd.
/ YM2310 clutch dragging #3
Yeah, drive it around and work it hard depressing the clutch pedal OFTEN and on and off the throttle OFTEN.... you have nothing to lose by trying....
No the disc isn't "swollen" but the hub is likely rusted on the input shaft....
I think because the higher gears require more torque the clutch slips.
That makes a lot of sense, the clutch disc being rusted on the input shaft. Too bad I can't squirt a little lube on the input shaft.
/ YM2310 clutch dragging #6
You can, all you have to do is split the tractor in half lol
Actually w a bore scope and a length of brake line you could probably do it through the starter hole but don't want to get it on the clutch...
/ YM2310 clutch dragging #7
A bore scope is probably worth the investment. Look on ebay or amazon for a usb one that will connect to a computer or phone. Get one that has built in lights.
It may allow you to assess what is actually happening. You may still have to split the tractor for repairs, but it may allow you go into the job knowing what needs to be replaced and having parts on hand, prior to separating.
/ YM2310 clutch dragging #8
There should be an inspection hole on the bottom or side of the transmission, it has a black rubber plug on it, it might be painted green to match the rest.
Its on the brake side of the machine.
Well, I found the inspection port on the brake side of the bell housing where I was told it should be. The rubber plug is really decayed so I hope I can order another. I was not able to look into the port because the tractor has a Bulldog front loader bolted on and it blocks line of sight into the inspection port.
So here is my evil plan: my son will bring back my endoscope and I will affix a small diameter vinyl tube to the 'scope. I will then try to maneuver the 'scope to the offending rusted splines on the input shaft. Then I will try to squeeze some oil, not very much, through the tube and onto the input shaft. Then I will try to rotate the shaft and apply more oil until the clutch is assured to slip. Or even better apply just enough oil for the friction disc to slide on the spline. I think this is not going to be easy. However, if it works it will surely be easier than splitting the tractor, especially since there's that pesky front loader bolted to the tractor that seems like it will really get in the way of splitting the thing.
/ YM2310 clutch dragging #14
I'm thinking a borescope would be a better choice but hey if you have some Propofol handy then I suppose anything's possible
BAWHAHAHAHAHAHA
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2026 Kearney 7'x20' Trailer (A64119)
2026 Kearney...
2019 Mercedes Sprinter 2500 Cargo Van (A61573)
2019 Mercedes...
