etpm
Veteran Member
- Joined
- Jun 30, 2021
- Messages
- 2,397
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Greetings All,
I just bought YM2310 tractor and the clutch drags. The clutch was stuck when I bought it but I was able to get it to slip when the tractor is in high gear. Now the clutch only works when I am using the tractor in third or fourth. I have adjusted the clutch according to the manual. I can tell that the clutch is not releasing completely. When I let the clutch out in third or fourth gear it grabs right away, I cannot feather the clutch. Should I just drive this tractor around with the clutch pedal depressed and let the clutch slip? Maybe that would wear away any rust. Or maybe the clutch disc itself is swollen and must be replaced. Any advice greatly appreciated.
Thanks,
Eric
Thanks,
Eric
