YM2210 rear seal
/ YM2210 rear seal #1
kayssupply
Platinum Member
S Illinois
Iseki TA 207
Can anyone help me with getting started changing the rear axle seal on a YM2210? I have always went in through the PTO cover on other tractors, but this one has the shifter up on the transmission. I assume you have to pull the shifter first. Is it easier to go through the PTO or by taking the lift assembly off and going in from the top? Also will the seal from an 1810/1820/ etc. fit?
/ YM2210 rear seal #2
You can call the shop tonight 509-374-3398 and I would be happy to walk you through it. It is not hard and can be done with simple tools.
2017 Gehl RS6-34 (A64119)
2017 Gehl RS6-34...
2022 Case 5550 Trident Spreader LOW HOUR (A63688)
2022 Case 5550...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2022 EZ-GO ELITE...
1066 (A64280)
1066 (A64280)
