Ym220 with low compression
/ Ym220 with low compression #11
From what I see the cyls/liners are probably useable? I would cut the ridge and like Winston mentioned I much prefer a dingle ball hone fact ring manufacturers recommend them and you might put 3 new pistons in if the cyl that had the broke rings didn't wear excessively they will wear a cyl out in no time when the pieces are just floating around.
Thanks for the help gentlemen, I appreciate it more then you know. I'm going to continue checking things out and get some measurements going. I'll update when I know something.
/ Ym220 with low compression #13
As Cardoc has advised before he prefers a dingle berry hone if one is available. Might read his post #s17 and 18 in this thread explaining why. http://www.tractorbynet.com/forums/yanmar/281240-ym-1700-head-gasket-2.html
Got to thinking about it Cardoc. I am hoping you understand I am just repecting your advice and passing it on. Hope you don't mind.
No problem anytime Winston feel free. In fact thanks for passing that along I didn't even see the thread for awhile. Anything I know is passed along freely so use it anyway you feel like that's why I post the info the way I do. thanks :thumbsup:
Update....
Okay so I'm finally able to work on this project again.:) After further inspection of my cylinder liners I decided to replace them all. After covering the crank with some plastic and then a wet rag, I welded four vertical lines starting at the bottom of the cylinder liners and moved towards the top, this shrunk the liner enough that i could pretty much pull it out by hand. Once I got started I think I go them out in about 30 minutes. I got new liners and rings from Hoye and those are all installed now. I lapped the valves just for good measure. My head is flat as best as I can tell and there was no signs that the previous gasket had any leaks.
New Problem.....
Yesterday I snapped one of the smaller head bolts..... like an idiot...... I forgot to oil them first:ashamed:. It also got me thinking that maybe I had some bad info on the torque specs. Does anyone have those? I haven't seen the specs for this particular model (my220d).
any advice is welcome!
/ Ym220 with low compression #15
Head bolts 29,58,72-79 ft lbs. Cylinder head assist bolts 22 ft lbs. Rod caps 32.4-36 ft lbs. valves .008"
So I discovered that Three of the head bolts have no gasket around them which exposes them to coolant. I snapped one while trying to get them up to torque and that's when I realized they have a weird waist / thinner area in them. I ordered replacements for all three. I've lost a few weeks just getting that sorted out.
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
2013 Haulotte 4527A (A57148)
2013 Haulotte...
2016 Chevrolet Malibu Sedan (A59231)
2016 Chevrolet...
HEAVYEQUIPMENT TOOLS (A60736)
HEAVYEQUIPMENT...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
