Ym2000 Steering Wheel Removal
/ Ym2000 Steering Wheel Removal #1
dondon
Can anyone tell me how to replace the steering wheel? I have removed the steering wheel cap, removed the nut. Seems like the steering wheel should pull off but it will not budge. Am I missing a step?
/ Ym2000 Steering Wheel Removal #2
Yep, you're missing the wheel puller. Any autoparts store, Home Depot, Lowes, hardware store should have something suitable.
/ Ym2000 Steering Wheel Removal #3
I spray PB Blaster on the shaft and let it set for a while. Put the nut back on until it is flush with the end of the shaft. Have a friend pull up on the wheel and take a SOFT hammer and tap the nut. Repeat the whole process until it pops up. Or get a puller.
/ Ym2000 Steering Wheel Removal #4
Yup, leave the nut on loosely to keep the steering wheel from flying off and hitting something when it breaks loose.
Thanks, kinda thought I may need a puller
/ Ym2000 Steering Wheel Removal #8
The nut also protects hollow shafts from deforming. Some slide a bolt down the shaft and center the puller on it.. etc.
Soundguy
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2002 International 9200i Truck (A61307)
2002 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
