Ym2000 Steering Wheel Removal
/ Ym2000 Steering Wheel Removal #1
dondon
Can anyone tell me how to replace the steering wheel? I have removed the steering wheel cap, removed the nut. Seems like the steering wheel should pull off but it will not budge. Am I missing a step?
/ Ym2000 Steering Wheel Removal #2
Yep, you're missing the wheel puller. Any autoparts store, Home Depot, Lowes, hardware store should have something suitable.
/ Ym2000 Steering Wheel Removal #3
I spray PB Blaster on the shaft and let it set for a while. Put the nut back on until it is flush with the end of the shaft. Have a friend pull up on the wheel and take a SOFT hammer and tap the nut. Repeat the whole process until it pops up. Or get a puller.
/ Ym2000 Steering Wheel Removal #4
Yup, leave the nut on loosely to keep the steering wheel from flying off and hitting something when it breaks loose.
Thanks, kinda thought I may need a puller
/ Ym2000 Steering Wheel Removal #8
The nut also protects hollow shafts from deforming. Some slide a bolt down the shaft and center the puller on it.. etc.
Soundguy
speed limit sign (A61572)
speed limit sign...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
211298 (A62131)
211298 (A62131)
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
2017 Ford Transit 250 Cargo Van (A61573)
2017 Ford Transit...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
