Ym2000 help
/ Ym2000 help #1
lancem
Martin,Ga
YM2000
I went out to crank my tractor and all I got was dash lights. The tractor would not turn over or click. I thought it might be a dead battery but the battery seems to be ok. The turn signals and grad lights work. Can someone walk me thru bypassing the ignition switch? Thanks
/ Ym2000 help #2
Have you check the terminal ends?, Many of us have found the problem is the ground wire to the chases/frame, remove the wire and clean or sand the area,
/ Ym2000 help #4
I would take off battery terminals and clean them along with the battery posts. If battery seems to be ok, please check the volts, note that the battery might show a full charge of 12 / 13 volts, but the amps, (CCA) cold cranking amps, might be a little low. It might be that a battery replacement in is store. Good luck. I have experienced the same thing.
/ Ym2000 help #5
Do you have the safety switch at the clutch on your tractor ????
/ Ym2000 help
Thanks everyone! I will clean the battery terminals and ground. Hopefully that will do it.
/ Ym2000 help
I finally tracked it down. It was the starter. I had it rebuilt and its working like a charm. I think it had been going bad for a while. Last summer i had to start using the decompression lever to get it started. Thanks for the advise.
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
2016 Nissan Altima Sedan (A64557)
2016 Nissan Altima...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
90in. Work Bench (A65640)
90in. Work Bench...
2022 EZ-GO ELITE...
Quick Attach Grapple Bucket (A66285)
Quick Attach...
