Ym2000 help
/ Ym2000 help #1
lancem
Martin,Ga
YM2000
I went out to crank my tractor and all I got was dash lights. The tractor would not turn over or click. I thought it might be a dead battery but the battery seems to be ok. The turn signals and grad lights work. Can someone walk me thru bypassing the ignition switch? Thanks
/ Ym2000 help #2
Have you check the terminal ends?, Many of us have found the problem is the ground wire to the chases/frame, remove the wire and clean or sand the area,
/ Ym2000 help #4
I would take off battery terminals and clean them along with the battery posts. If battery seems to be ok, please check the volts, note that the battery might show a full charge of 12 / 13 volts, but the amps, (CCA) cold cranking amps, might be a little low. It might be that a battery replacement in is store. Good luck. I have experienced the same thing.
/ Ym2000 help #5
Do you have the safety switch at the clutch on your tractor ????
/ Ym2000 help
Thanks everyone! I will clean the battery terminals and ground. Hopefully that will do it.
/ Ym2000 help
I finally tracked it down. It was the starter. I had it rebuilt and its working like a charm. I think it had been going bad for a while. Last summer i had to start using the decompression lever to get it started. Thanks for the advise.
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
Bush Hog 18ft. Disc (A65640)
Bush Hog 18ft...
2016 Ram 2500 6.4L HEMI (A62679)
2016 Ram 2500 6.4L...
White Oak Boards (A65640)
White Oak Boards...
2006 Kenworth T800 Tandem Dump Truck, VIN # 1NKDLU0X26J147788 (A65563)
2006 Kenworth T800...
Vermeer SC30TX Smart Sweep Stump Grinder (A62679)
Vermeer SC30TX...
