Ym2000 help
/ Ym2000 help #1
lancem
Martin,Ga
YM2000
I went out to crank my tractor and all I got was dash lights. The tractor would not turn over or click. I thought it might be a dead battery but the battery seems to be ok. The turn signals and grad lights work. Can someone walk me thru bypassing the ignition switch? Thanks
/ Ym2000 help #2
Have you check the terminal ends?, Many of us have found the problem is the ground wire to the chases/frame, remove the wire and clean or sand the area,
/ Ym2000 help #4
I would take off battery terminals and clean them along with the battery posts. If battery seems to be ok, please check the volts, note that the battery might show a full charge of 12 / 13 volts, but the amps, (CCA) cold cranking amps, might be a little low. It might be that a battery replacement in is store. Good luck. I have experienced the same thing.
/ Ym2000 help #5
Do you have the safety switch at the clutch on your tractor ????
/ Ym2000 help
Thanks everyone! I will clean the battery terminals and ground. Hopefully that will do it.
/ Ym2000 help
I finally tracked it down. It was the starter. I had it rebuilt and its working like a charm. I think it had been going bad for a while. Last summer i had to start using the decompression lever to get it started. Thanks for the advise.
KUBOTA L3940 TRACTOR (A64277)
KUBOTA L3940...
2015 ABU TRAILER 14 FOOT UTILITY TRAILER (A65643)
2015 ABU TRAILER...
2022 CAT 289D3 Skid Steer (A62613)
2022 CAT 289D3...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
