Ym2000 help
   / Ym2000 help #1
lancem
Bronze Member
Martin,Ga
YM2000
I went out to crank my tractor and all I got was dash lights. The tractor would not turn over or click. I thought it might be a dead battery but the battery seems to be ok. The turn signals and grad lights work. Can someone walk me thru bypassing the ignition switch? Thanks
   / Ym2000 help #2
Have you check the terminal ends?, Many of us have found the problem is the ground wire to the chases/frame, remove the wire and clean or sand the area,
   / Ym2000 help #4
I would take off battery terminals and clean them along with the battery posts. If battery seems to be ok, please check the volts, note that the battery might show a full charge of 12 / 13 volts, but the amps, (CCA) cold cranking amps, might be a little low. It might be that a battery replacement in is store. Good luck. I have experienced the same thing.
   / Ym2000 help #5
Do you have the safety switch at the clutch on your tractor ????
   / Ym2000 help
Thanks everyone! I will clean the battery terminals and ground. Hopefully that will do it.
   / Ym2000 help
I finally tracked it down. It was the starter. I had it rebuilt and its working like a charm. I think it had been going bad for a while. Last summer i had to start using the decompression lever to get it started. Thanks for the advise.
Payment Instructions (A47384)
Payment...
CATERPILLAR 239D SKID STEER (A51242)
CATERPILLAR 239D...
2025 LandHero Universal Bucket Pins (A49462)
2025 LandHero...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A51222)
2013 FREIGHTLINER...
MAHINDRA 2816 TRACTOR (A51243)
MAHINDRA 2816...
