YM2000 general maintenance
/ YM2000 general maintenance #1
callais
Picayune, MS
yanmar 2000
I'm about to start some maintenance on my YM2000. Can anyone tell me what's the best oil to use, hydro oil, etc.
Does NAPA have the fuel, air and oil filters, and if so what are the part numbers? <----------(This is what I'm really having trouble with).
Also, when I drain my radiator, how much antifreeze should I mix with the water, I live in Southern Mississippi, so actual freezing won't be a problem.
Thanks in advance.
/ YM2000 general maintenance #2
Oil----Shell Rotella T 15W40, gallon jug. Please don't ask how much, just fill it up. It ain't rocket surgery.
Hy/tran---Universal hydraulic/transmission fluid,(consistent with JD303, it says on 5 gal can). Clean your pickup screen.
antifreeze----50/50, approx. 1 gal mixed.
NAPA oil filter---1064
Air---2297
fuel---3262
/ YM2000 general maintenance #3
normde2001, you make it sound so easy that anyone could do it! You're going to put all the rocket surgeons out of business! /forums/images/graemlins/grin.gif
Thanks for y'all help, I keep this in my notes.
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
Quick Attach Grapple Bucket (A66285)
Quick Attach...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2022 EZ-GO ELITE...
