YM1700 normal operating temp
/ YM1700 normal operating temp #11
That's still too much coolant. Assuming you have not installed a waterpump, I would drain it and cut 50/50 again with water, which would give the proper 75/25 mixture. Also make sure the system is clean, (backflush), inside and out.
/ YM1700 normal operating temp #12
[...temp of about 220...]
The conventional wisdom seems to be that that is a high temp. It is not for an automobile. I wonder what the operating temp is for Yanmars with thermostats? I'm still running 50-50 antifreeze with my 1500D with no problems.
/ YM1700 normal operating temp #13
I have the Sunpro temp gauge setup on my 1700. I have not run anything on the PTO. I have been running it hard in the sun down here (80 to 85) with a 4' boxblade. It is real hard to get it over 170. I run 30/70 with water wetter. It could be my gauge is not calibrated properly. It has been over 200 on occasion. I had several leaks in the radiator and hoses, all fixed. I noticed when the cooling system is working right, I see little bubbles coming out of the overflow hose into the overflow bottle. At least right after I have refilled after the leaks were fixed. I have seen people claim on here that their 1700 has a water pump. Mine does not. I'll have to check the cap again. There was some controversy here on the pressure it opens at.
/ YM1700 normal operating temp #14
I have a 1700B with a water pump.
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
1965 Fontaine PS2824SP 28FT 15 Ton S/A Flatbed Trailer (A59230)
1965 Fontaine...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2014 Freightliner Cascadia 125 S/A Day Cab Truck Tractor (A59230)
2014 Freightliner...
