YM1700 injector timing question
   / YM1700 injector timing question #1
goose117
Yanmar 1700
Hello - I've read through many of the injector timing questions and answers but am finding my attempt at checking the timing confusing so I'm thinking I'm interpreting the instructions incorrectly.
My process has been to remove the injector lines from the injectors, manually turn the engine, then watch for fuel to come out of the the injector lines. The fuel just sorts of barely dribbles out of the lines at certain points during the engine rotation.
What I have got so far is that the rear (#1) injector line (see photo), connected to the front port on the injection pump, seems to output fuel when the timing pointer is between the #2 TDC and #2 timing mark (see other photo). This doesn't make sense to me. I checked and this is when the rear cylinder is at the top of its movement.
Can anyone help clarify if I need to change my method or interpret these results in a way that seems consistent with aiming for the fuel to be injected 22 dg before the #1 TDC timing mark? I've also included the instructions in the manual I have.
One other question - does the injector timing that is done when adjusting the governor effect where injection occurs per these timing marks?
Thank you.
  • timing marks when rear injector line has output and rear cylinder at TDC.jpg
   / YM1700 injector timing question #2
I personally like the method given in the I&T manual for the 195 which would be the same as your 1700.
Thanks! This has more detail so I will give it a try.
   / YM1700 injector timing question #4
Quick note but very important…
Where it says remove the delivery valve .. they mean THE CENTER of the dv.. NOT the entire thing..
Good luck
So I took out delivery valve and spring from the forward (#1) pump port then attached a clear tube. When I turn on the fuel at the fuel filter the tube fills up to the height of the fuel in the gas tank. However when I turn the engine over manually (CW) or turn over with the starter (injectors are removed), I don't see any movement of fuel in the clear tube. I know with the injectors attached they fire regularly so I'm wondering why I don't seem to see any fuel being pumped from the injector pump (making sure the fuel is turned on)? The pictures show the parts I've removed and the clear tube setup for monitoring the fuel coming from the pump.
   / YM1700 injector timing question #6
Do u have the throttle about 1/2 way on and not in the shut off position.?
It’s a throttle shut off and not an electric sol. right.?
Put the throttle on 1/2 way..
If it’s electric, turn the key on.
Thanks for the suggestion. The throttle is all the way back (max open). Here's a link to a short video showing the lack of fluid motion in the tube with the throttle open and fuel on. fuel not pumping for timing check.mp4 (not sure if this is how videos are shared here).
I have the injectors out so that's why there's no compression. I didn't take them out for the timing check but they just happen to be out while I'm doing this.
   / YM1700 injector timing question #10
Pumpguy knows far more about this stuff compared to us amateurs but I'm not bashful about sharing an uninformed opinion :D.
I think the amount of fuel expelled per injection, every two revolutions of the crank, is so tiny that the vibration of the engine being cranked, has a far larger effect on the level in that transparent tube. And - look at the turbulence where the tube is connected to the engine. Something is going on there. Looks to me like bubbles.
So - I don't think the level at the upper end of the tube is telling us much. Pumpguy?
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52128)
2018 Dodge Ram...
2000 KOMATSU VALMET 860.4 FORWARDER (A51222)
2000 KOMATSU...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
John Deere 270 Compact Wheel Loader Skid Steer (A50322)
John Deere 270...
