YM1700 Draft control?
/ YM1700 Draft control? #1
Popstoy43
My 1700 has a handle on the drivers side lift arm that I assume is for the draft. There is an adjustment nut threaded at the end of the rod. Also the rod has about three holes drilled in it. It seems to make no difference which position the handle is in. Does anyone know the procedure for proper adjustment of draft? Thanks
/ YM1700 Draft control? #2
So would that be left or right drivers side? /forums/images/graemlins/smile.gif
I don't know of the 1700 having draft controll.. unles sthis was some sort of external feedback linkage a previous owner cooked up, that would adjust the 3pt control handle.. etc.
Soundguy
/ YM1700 Draft control? #3
Don't think it is draft control but my 3000 has the same thing on the left 3 point arm that is linked to the valve that controls 3 point arms up and down. This is a factory set up Soundguy. I asked at the importer what it is, no one knew. They had many on the floor with this feature. ( 20 or so of the 100 yanmars there had this feature ) Rocker that all of this is linked to presses a plunger raising or lowering the 3 point. I have a couple of operators manuals for mine and none address this feature, what it does, how to adjust.???? I to would be highly interested in what this setups intended use is.
Chris
/ YM1700 Draft control? #4
</font><font color="blue" class="small">( some sort of external feedback linkage )</font>
I think you nailed it, but it is not something added on. I'm not sure I can explain clearly but I believe it is a position feedback for the 3 point. I have seen them on the Yanmars before. I had one come loose and the hitch started acting real eratic and when I found and tightened the culprit, all was well.
/ YM1700 Draft control? #5
That was my first thought.. Fergie tractors and Ford N's also had a factory aftermarket 3pt feedback linkage as well as many many home brew setups. The attatched to the lift arms in various ways.. and used springs.. levers, and friction discs to modulate the lift handle for various things. In the fergy/ford case.. they turned draft 'only' hyds.. into psuedo 'position' control. I'm sure there are setups where as the implement follows the terain, that the falling implement could them modulate the 3pt handle to change something.
I like seeing neat mechanical linkages like that.. kinda reminds me of Rube Goldberg type stuff.. or clockwork.. etc.
Soundguy
/ YM1700 Draft control? #6
While we are all standing around prognosticating.. post a pic of that linkage.. I've not personally seen one on a yanmar.. a visual clue may go a long way towards an explanation.
Soundguy
/ YM1700 Draft control? #7
Tractors4u is correct . If you didn't have the linkage the control valve would keep supplying oil to the lift cylinder. If you adjust the rod it should change how far the 3 point raises or dropd.
/ YM1700 Draft control? #8
Hmmm. The operation manual says connect the feedback rod only to the 'P' hole, never the 'D' hole... Could D mean Draft Control?
Here's the diagram.
/ YM1700 Draft control? #9
</font><font color="blue" class="small">( So would that be left or right drivers side? /forums/images/graemlins/smile.gif
I got it!!! Funny!!!
I'll take a pic. tomorrow and post. By the way it's on the left drivers side unless you are sitting in the seat backwards. /forums/images/graemlins/cool.gif HE HE
/ YM1700 Draft control? #11
With all implements removed from the 3 point arms on my
YM 3000, I can lift the lower arms by hand and the hyd. lift will take over and lift the 3 point on it's own. There is about a inch or two of lifting by hand before the 3 point takes over and as long as there is upward pressure on the arms the 3 point will continue to lift. Stop lifting and the arms fall back into position. What would you call that function???? What might be the intended use???
Chris
/ YM1700 Draft control? #12
Sounds like 'float' .. not conventional draft In fact.. backwards of draft.. ). Draft lifts the arms if they suck into the ground too far.. or otherwise encounter heavier 'draft' resistance. Your setup is is more like feedbackcontrolled lifting...??
Soundguy
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2022 EZ-GO ELITE...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
Pemberton Inc 416469 72in. Loader Forks and Frame (A64194)
Pemberton Inc...
New/Unused 20ft Metal Farm Driveway Gate (A65583)
New/Unused 20ft...
