YM1700 Draft control?
/ YM1700 Draft control? #11
With all implements removed from the 3 point arms on my
YM 3000, I can lift the lower arms by hand and the hyd. lift will take over and lift the 3 point on it's own. There is about a inch or two of lifting by hand before the 3 point takes over and as long as there is upward pressure on the arms the 3 point will continue to lift. Stop lifting and the arms fall back into position. What would you call that function???? What might be the intended use???
Chris
/ YM1700 Draft control? #12
Sounds like 'float' .. not conventional draft In fact.. backwards of draft.. ). Draft lifts the arms if they suck into the ground too far.. or otherwise encounter heavier 'draft' resistance. Your setup is is more like feedbackcontrolled lifting...??
Soundguy
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
Massey Ferguson 4707 (A60462)
Massey Ferguson...
2017 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60352)
2017 Ford F-550...
2019 Dodge Charger Sedan (A59231)
2019 Dodge Charger...
John Deere 6110M (A53317)
John Deere 6110M...
