YM1300D - front 4x4 doesn't work
/ YM1300D - front 4x4 doesn't work #11
I'd go to the driveline, unbolt the flanges and remove the driveline. The driveline uses ball bearings on each end to form a CV joint at eather end. What you discribe could be worn or missing drive balls, or a gear problem somewhere in the front end. Drive balls are cheap, I'd look there first, also the easiest tear down. Once the cover is slipped back you will find one end is under spring tension, pry it back with a big screwdriver, remove the drive line. If you don't find a problem with the drive line, leave it off and jack up the front end. Spin each front tire by hand and see if it turns smooth. If it does, most likely the drive line, if it doesn't, time to tear down the front end. Tearing down the front end isn't that hard, but gears aren't cheap, sometimes hard to find. If you have to get in there, replace all of the bearings and seals while you are in there. Don't want to do it twice. Good luck,
Chris
Chris
/ YM1300D - front 4x4 doesn't work #12
It sounds like the seal is bad if it continues to leak. Probably just ready for replacement. I'd say tear that side down and inspect the internals to be sure the gears have not been damaged.
/ YM1300D - front 4x4 doesn't work #13
my 1300D does not have cv-joints, it has u-joints. Hoye doesn't have them so you will have to find some at a driveline co. to replace.
John Deere 995 (A60462)
John Deere 995...
Ford 8510 (A53317)
Ford 8510 (A53317)
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
Giyi XKH39 (A60463)
Giyi XKH39 (A60463)
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59906)
2004 INTERNATIONAL...
