YM 226
/ YM 226 #1
F350
USA
Red
Well I pulled the trigger and bought the YM 226 that I was looking at. I bought the tractor and bushog
for $3500.00 cash. The only thing that I found other than non-functioning headlights is the valve cover gasket leaks a little oil. I have a couple of Yanmar newbie questions.
Is the valve cover gasket hard to change? Where can I get the gasket?
Are there any crossover part numbers for the air and oil filters on the YM 226?
I searched through the old posts but came up empty. Any help and advice would be appreciated.
/ YM 226 #2
F350
A YM226 isn't a gray model, so you can go directly to an authorized Yanmar dealer, unlike most of us with gray units.
I don't know where you are because your profile isn't filled out, but you can go to Yanmar's web page and find a distributor in your area.
Tom
/ YM 226 #4
I have had to replace valve cover gaskets on two YM1110D's. On the 2T72 engine in them, the valve cover gasket is a rubber o-ring thingy with a round cross-section formed to the right shape for the valve cover. They both leaked and I ended up putting a very thin layer of rtv on the gasket and then installing the valve cover. This took care of the leak.
2018 TAKEUCHI TL8 SKID STEER (A59914)
2018 TAKEUCHI TL8...
72" JCT TILLER (A62613)
72" JCT TILLER...
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
