YM 2220D too narrow
/ YM 2220D too narrow #21
How did you arrive at that safety margin of 2?
/ YM 2220D too narrow #22
For steel, it is common to use a safety margin of two (this is application dependent). You do not want to design to the breaking point of steel. This is a rather simplistic model for the forces encountered, so the safety margin is also a way to account for some of the more complicated or unexpected stresses that may be encountered.
Also, the previous calculations do not account for dynamic forces. These tractors move rather slow and have large tires to absorb some of the shock, so the dynamic forces should not be extreme.
/ YM 2220D too narrow #23
Stress from bending is somewhat different from stress from pulling. The previous calculation was for the latter. For bending, max stress on the ansle is (bending moment)x(radius)/(moment of inertia). Using 2" diameter, 8" from outer bearing to wheel, 1000 pound load on the wheel, I get a number like 10200 psi. Axle is most likely a hardened steel with yield stress of 50,000 psi or greater. I doubt that the axle will snap even with dynamic load. But you are increasing the chance the axle may fail by small crack growth such as fatigue. (I really don't think it is likely)
But increase in bending moment (as previously said, 33% increase) will increase the load on the bearing. It may fail way before the axle fails by fatigue type cracking. In my uneducated opinion (I don't even have a tractor yet), safety improvement from wider wheel span (if it is real) outweighs the safety compromise due to premature failure.
That's my 2 cents.
Wow!
That's an amazing 2 cents, rlee6.
Even if you are only half right (I just don't know, I've never seen calculations like these) it confirms for me that I should pursue my plans to widen that footprint on my tractor.
Herbert
/ YM 2220D too narrow #25
Zoster,
I re-read the whole thread and noticed HoyeTractor's comment on some engineer estimating doubling stress for every 1/2 in extension. THIS COMMENT BOTHERS ME. Since I don't have a tractor and don't know how a wheel is mounted, I cannot say for sure if his comment can be safely rejected.
So, please tell me someone how a wheel is mounted on the axle. I was relying on another post that mentioned 2" diameter axle, 6" distance between the outer bearing and wheel center. In other words, the outer bearing is the last support of the axle. From then on, the axle is just sticking out freely. If this is the correct description of the axle/wheel, then the other engineer was wrong. There are 2 components of stress on the axle. One is torsional stress which should remain same. Only bending stress increases in proportion to extension. Combination of the two stresses does not magically increase total stress.
Zoster,
Before taking off with the idea, can you talk to an engineer? Or, can you post some pictures for me?
HoyeTractor,
What kind of engineer was he? I am not challenging him. I just don't want to extend beyond my capability.
/ YM 2220D too narrow #26
Maybe an engineer...hmmm maybe a good physics professor at your local college/high school. They may take this on as a project/problem for the class.
We know the mass of the tractor stays relatively constant. The vertical force exerted on the drive shaft (not rotational force)certainly changes with load (bouncing, bumps, etc).
If each outer bearing sees a 600 pounds of force statically (only a rough estimate), that force will increase with bumps etc. Also if you exert that same 600 pounds at a farther distance shouldn't you exert a greater force at the bearing. Think torque wrench or when you slip a pipe over your socket wrench handle to get extra power.
One question is does all the increased force act at one bearing point or is it divide force at two bearing points. Also what total force can the bearing take (might call Timkin bearing in Canton Ohio on that one).
Generally I think an engineer would be the right person to answer this. I have only farmboy questions and gut feelings...no real answers /forums/images/graemlins/grin.gif I can't imagine small spacers make any significant change. Maybe someone with a similar "domestic" tractor of similar size (eg a John deer 650 or one of the Kubotas) could call the factory rep and ask what the think. I imagine manufacturing specs are similar with these machines.
OK, so I ramble with no real help/goal/info...I just find these type of questions interesting and love learning from everyones knowledge. Hopefully we get an answer. I think Htiak126 is the star so far. I am just not sure if all the increased stress is applied to the inner bearing surface (i.e. the outer bearing only acts as a pivot point without risk of increased force).
I think we needs wun of dem der twaktor enginears to cypher dis wun. /forums/images/graemlins/confused.gif
Peter
/ YM 2220D too narrow #27
Hello all
I hve been reading this post, and it peaked my interest. As a mechanical engineer by profession, I was curious about how adding a spacer to widen your track width affects the stress on the axle and the load on the bearing. Well being the nerd that I am, I plopped myself down in Excel and banged through the calculations required to determine the axle stress and deflection of the axle vs/ spacer length. I was surpirsed to see not a a huge increase as spacer length is increased ( it definitely is not 2x per 0.5in increase in spacer length as someone earlier mentioned). I have attached an Excel spreadsheet which you can download and play with for yourself. To summarize the data:
Assuming a 6 in spacer per side (worst case)
You have a safety factor of at least 3 for torsional stress, torsional deflection, bending stress, axle deflection (sag), shear stress, and radial load on the bearing.
In the engineering world, something with a safety factor creeping up on 4 is considered "tractor engineered" no pun intended. Most tractors are way overdesigned mainly b/c weight is not a negative but a positive, and you never know what someone will try to do with a tractor.
Note:
my calculations are for static loads only and do not incorporate fatigue - this is why a safety factor is used - to account for these things.
I think you will be fine with the spacer, whenever I get a tractor I will make me some.
PS - if anyone needs spacers, I can design some in Solidworks for you and provide you with prints to take to your local machine shop (free of charge of course) or machine them for you myself.
/ YM 2220D too narrow #28
</font><font color="blue" class="small">(
)</font>
I will take a rain check. I don't have a tractor yet but soon I will need a spacer myself.
Thanks for the calculations and numbers.
/ YM 2220D too narrow #29
Philip,
Welcome to TBN. You will find that members on this site are very creative and make many of their own parts and attachments with amazing results.
It is always nice to have shared ideas backed up with a gracious offer like yours. I will bookmark your name with others for my future plans.
Thank You and regards, Mark
/ YM 2220D too narrow #30
Philip,
Nicely done spreadsheet. My only comment is that the change in stress from adding a specific thickness spacer will be a strong function of the separation between the inner bearing and the outer bearing. You have shown this separation as 6", which may be a bit high for the smaller tractors.
/ YM 2220D too narrow #31
Very nice work! Isn't the Internet great. The engineer that I spoke with was with a major transmission manufacturing company (names withheld to protect the innocent). Like I said, it was a long time ago and I cant remember the exact numbers he came up with. It made sense though that the further you spaced out the wheels the more leverage there was on the axle and bearing carriers. I doubt that 2 or 3" is enough to cause problems though. Im sure the tractors are designed heavier than needed.
Aaron,
Parts@HoyeTractor.com
(940) 438-0386
/ YM 2220D too narrow #32
Yes, the internet is amazing. Thanks very much to the members who invested time and thought in calculations on this subject. It's good to have "country boy" guesstimates bolstered by 'rithmatic & engineerin'. I'd even be tempted to try thicker spacers, but my 2" ones have added the stability I wanted without making the wheel track wider than my tiller and give the tractor a more appealing "stance", methinks.
And they were easy to obtain. Just took a wheel to a machine shop around the corner where they measured it, found the dimensions to be unremarkably standard, and called me in a couple of days to pick up the spacers. Pretty simple way to gain stability on my hilltop.
When I posted this spacer-thingy question (which was my very first post on this forum) I expected maybe three or four replies. The interest in this issue and the time many of you invest to help out, just plain and simply boggles my mind.
Thank you very much to all of you who went through the trouble of thinking about this and then to share your expertise/ gutfeelings/ experiences/ opinions/ knowledge.
Herbert
/ YM 2220D too narrow #34
Phillip_l
I also didn't figure it would amount to a huge diference. Since the prevelance of adjustable width axles and rims, and dual rim combos have been around for soooo long. Heck.. the old JD's had splined axle stubs, and you slid the rim and hub out as far as you needed it.
Even the old 'small' fords could run dished out rims or full dual setups or mud paddles outside regular rims.. etc.
Soundguy
/ YM 2220D too narrow #35
Phillip L,
WOW what a first post. Thanks for the advice backed by brains and "figurin." Makes me feel better that I am not destroying my ltttle tractor.
Thanx
Peter
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Frontier Grapple (A64127)
Frontier Grapple...
