YM 1700 Water Temp
/ YM 1700 Water Temp #1
meisal
Louisiana
YM 1700
OK I finally put a water gauge on. The temp stayed between 190 and 210.
Most of the time while working it the temp was closer to the 210 mark.
Does this sound OK?
I cleaned the radiator and screen. Have not had it cleaned professionaly and have not changed the antifreeze to make sure it has proper mixture.
Reading this forum most say to run 70/30 mixture.
My manual says to use a 40% antifreeze/water mixture.
Am I running too hot?
What is the max temp before i should be really concerned?
Thanks
I love my Yamar!
/ YM 1700 Water Temp #2
Does this sound OK?
Thanks
I love my Yamar!
The answer is the YM1700 temp sending unit is set to come on at about 248 degrees.
Danny
/ YM 1700 Water Temp #3
Does this sound OK?
Thanks
I love my Yamar!
30% antifreeze, 70% water.
Danny
/ YM 1700 Water Temp #4
That sounds a little high to me. Mine (1700 no water pump) runs no more than 160 even when it is 95 degrees outside. However, I had the radiator rodded and clean by a radiator shop, flushed the block, and use the 70% water to 30% antifreeze mix as well.
/ YM 1700 Water Temp #5
Get your radiator rodded out...........I bet that fixes it............. You can add a YM2000 water pump to it also...........I think Danny Parker and/or Hoye Tractor has the kits..............Getting the radiator rodded out will more than likely fix it, but I'd put the water pump too just for more peace of mind for myself, personally.
Travis R
/ YM 1700 Water Temp #6
Yep, Travis' YM2000 was running 190 to 210 with a 6' finish mower until rodded and now it's 160.
OK Thanks all.
I'll get the radiator checked out.
Sounds easy enough.
2019 Freightliner 122SD (A62679)
2019 Freightliner...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
2012 INTERNATIONAL PROSTAR+ 122 6X4 ROAD TRACTOR (A65054)
2012 INTERNATIONAL...
ITS 16 Pipe Squeezer (A68842)
ITS 16 Pipe...
PAIR OF TRACTOR TIRES AND RIMS (A67714)
PAIR OF TRACTOR...
Unused 2023 Maybridge M79 3 Point Hitch Carrier Chain Harrow Lift Tractor Attachment (A66734)
Unused 2023...
