YM 1700 sleeves
/ YM 1700 sleeves #1
kryp
Can anyone tell me if the YM 1700 has wet or dry cyl seelves?
/ YM 1700 sleeves
You are a great help to me Allen, I think the water is passing the o-rings on the seelves to the base. Now do you sell parts buddy?
/ YM 1700 sleeves #4
No I don't. You need to talk with Leonard, Bruce or one of the other dealers that frequent this board.
/ YM 1700 sleeves #5
The YM1700 sleeves are no longer available. The good news is you can use YM2000 sleeves, pistons, and head gasket and therefore have a bit more horses.
Thanks,
Bruce
parts@yanmartractors.com
866 794 4498
/ YM 1700 sleeves
ygm.... and I will phone you tomorrow.
/ YM 1700 sleeves #7
Does the block have to be machined to accept the ym2000 sleeves? or is the outside diameter the same?
How much more HP do you estimate with the new pistons, etc.
Does this cause any valve problems?
Chris
/ YM 1700 sleeves #8
The sleeves fit with no machining because the blocks are the same. It is hard to estimate HP because the injector pumps are different. No valve problems.
Thanks,
Bruce
/ YM 1700 sleeves #9
This looks like a question for ( drum roll ) Roger Scotty (echo)
Roger... hypothetically replacing a ym1700 cylinder sleeves with ym2000, and acompianing pistons, etc.
Is ther more CI displacement? I'm assuming yes... if the id of the sleeves is less than the 1700's. Now, the injector pump is still calibrated for the lower ci... will there be mixture problems ( lean? etc? ) ( higher air volume... same amount of fuel injected )or will it be necescary to adjust the pump, or would it run without adjustment?
Just wondering...
Chris / Soundguy
"The sleeves fit with no machining because the blocks are the same. It is hard to estimate HP because the injector pumps are different. No valve problems.
Thanks,
Bruce "
/ YM 1700 sleeves #10
Since the HP will increase, what about engine cooling? Since the 1700 does not have a water pump, I would assume the propensity for overheating will increase? Just wondering if anyone has already been through a 1700 rebuild and used YM2000 piston/sleeves?
/ YM 1700 sleeves #11
I don't have my manual handy, but I strongly suspect the difference in bore size will go totally unnoticed except with a micrometer. No different than boring a car engine to clean it up.
/ YM 1700 sleeves #12
I was beginning to think that.. especially if the block is the same size. Add to that... if the block is the same.. that means the 1700 sleeves have a thicker wall than the 2000 sleeves... I think I would rather have the thicker walls....any comments?
Chris / Soundguy
/ YM 1700 sleeves #14
That's a bigger difference than I would have thought, however it should work.
Kryp, I hope you have done enough troubleshooting to convince yourself this is the problem, as it will be an expensive repair if wrong. I looked back to your original posts on Yahoo and you mentioned water squirting up thru head but couldn't tell from where. (valve guides?) I would check that block really close for cracks and if sleeves are leaking there will probably be corrosion.
/ YM 1700 sleeves
I am not sure what my next step will be on this one, I wanted to get the head pressure tested but it seems no one here does it. I had the head magafluxed and shaved but a pressure test would tell all on the head, looks like I may have to ship the head off for that or make a plate to bolt on it and do it myself and then use the plate on the block but I am not sure if standard water pressure will be enough of a test. I can also drop the pan yank out the sleeves and change the just the o-rings for a cost of about $50.00 in parts and thats the game plan I have so far.
/ YM 1700 sleeves #16
Sounds like some good ideas. If you can make a plate to bolt over the block, you could use a radiator pressure tester, I don't think too expensive, to test the block. Don't know how you could pressurize the head. If you get a leak then pull the sleeves and inspect everything carefully with a good light and a big magnifying glass.
/ YM 1700 sleeves
To test the head I would bolt the head and plate together with a gasket, seal front water pully housing and use the upper radiator outlet to test with. Radiator pressure tester(Hum) sounds good to me and that will be my next step unless I am missing something about the head your talking about. I know I can not see to much topside on the head but it should let me know on a crack.
thanks
/ YM 1700 sleeves #18
Kerry,
We can check and/or repair the head if you have no one else near you. One year warranty on the head.
Thanks,
Bruce
2022 Case CX145D SR Hydraulic Excavator (A61572)
2022 Case CX145D...
2015 Dodge Journey SXT SUV (A61574)
2015 Dodge Journey...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
Caterpillar D6H and D6H Series II Tractor Service Manuals (A63117)
Caterpillar D6H...
