YM 1700 Seat
/ YM 1700 Seat #1
SailorBob
Mobile, AL
Yanmar YM1700
Okay guys after about 10 hours of seat time this weekend I have decided that the factory seat has to go. My seat is killing me. It is obvious these seats were made for the smaller Japenese behinds. Does anyone who has upgraded their seats have any suggestions?
/ YM 1700 Seat #2
No but I think I will tell the wife that I want one with a hydrolic piston for my birthday present.. I too have had the 8 hr butt ache.........
/ YM 1700 Seat #3
Replacing those rubber bumpers with a set of generic exhaust flange springs, ("HELP" bagged item), is a big help.
/ YM 1700 Seat #4
I replaced those rubber bumper thingies with military surplus springs I found locally. Sure helpd a lot. Most of the springy suspension seats are too wide to fit on the 1700.
I think I had posted some pics of my seat springs on here. I'll try to find them.
Edit.......here's one seat springs
/ YM 1700 Seat #6
Do you happen to remember where you found those springs locally? Just curious, might do the same thing to mine. Thanks!
/ YM 1700 Seat #7
Topper's Steel Supply on S. High St. in Columbus. I can check, if you want, to see if they have any left. I bought those a few years ago.
/ YM 1700 Seat #8
I bought a new seat from Northern tool, $34.95 if I remember right, had armrests too! It also makes me sit a bit higher, and after I lubed the seat track so that it would adjust I could get it back a bit further too, much better. How did you attach the bottom end of those springs under the seat?
/ YM 1700 Seat #9
I split a 1/4" fender washer and twisted it to match the spiral of the springs. Slipped it in and ran a 1/4" through it.
/ YM 1700 Seat #10
</font><font color="blue" class="small">( Topper's Steel Supply on S. High St. in Columbus. I can check, if you want, to see if they have any left. I bought those a few years ago. )</font>
Thanks for the info, I'll check it out when I have some free time. Maybe I'll stop by there next time I'm over that way. Sounds like the kind of place that may have some other stuff I can't live without /forums/images/graemlins/grin.gif
/ YM 1700 Seat #11
Feel free to check them out anytime you're in town, but for now e-mail me an address. I went down and picked 2 up for you. They had maybe 15-20 left.
/ YM 1700 Seat
Thanks for the info. I measured the distance between the fenders and there is only about 18" clearance. That limits the choices. Maybe I will try some more padding and springs before investing in a new seat. You can really spend a lot of money getting all the little tractor enhancements and accessories that you think you can't live without. For instance I still need front bumper weights, tilt meter, work light, tool box, etc. Since buying the tractor I have bought a box blade, bush hog, oil pressure gauge, temp gauge, sway chain (it vibrated loose and came off), fuel can, water wetter, air compressor, oil filter wrench, set of Craftsman wrenches, bimetal hole saw, hydraulic jack, etc. Wow! I just realized how much the tractor really costs. /forums/images/graemlins/blush.gif. I hope my wife does not realize it. They say a sailboat is a hole in the water where you pour money. I guess that makes a tractor the land based equivelant. /forums/images/graemlins/tongue.gif
/ YM 1700 Seat #13
Thanks! E-mail on it's way! /forums/images/graemlins/grin.gif
/ YM 1700 Seat #14
Thanks for the info, I was envisioning some sort of flat with a bend over each of the coils and bolted thru the middle, your way sounds much easier! I have some springs off an office chair that I'm going to add to mine, hence the question. I also thought I might just weld the bottom of the coil down...........
It's pretty narrow getting on and off my 1602D, so I'm going to replace the rubber bushings at the front where it tilts with some bronze bushings, it tends to tip when I put weight on one side when climbing in and out..............
/ YM 1700 Seat #15
Finally got around to snapping a picture. They fit perfect into the existing rubber bushings. No tools required!! /forums/images/graemlins/grin.gif Now I've got a little bounce in the seat, and it's not leaning way back. Thanks again!
/ YM 1700 Seat #16
The seats seem to be one of the differences between the US and Japanese Yanmars. The seat on my YM240 is comfortable. It's the same shape and size as those molded plastic cafeteria chairs, with an adequately high back. I've seen two different posters on TBN also describe these as comfortable.
My local Deere dealer once carried the Yanmar-USA line and can still order parts. He told me he ordered a YM240 seat for a YM2000 and it was too wide to fit the mount. I tried to get a YM2000 seatcover off ebay for my YM240 but the dimensions were too small, and the YM2000 seat I got from the local VN importer was for the narrow mount shown in cwarrix's photo, not the wider mount on my YM240.
If anyone ever gets the opportunity to salvage the seat and mounting hardware off a YM240, I recommend go for it.
/ YM 1700 Seat #17
I just checked your brochure, and you are right, the YM240 does have a nicer seat than even my semi-high back, YM2000B.
/ YM 1700 Seat #18
My biggest complaint was that the seat was leaning way back. I'm assuming because the little rubber things are worn, but maybe it's just designed that way. Anyway, adding the springs brought it right up where it's not leaning anymore, and it now has a little bounce to it, even with 220 pounds sitting on it /forums/images/graemlins/grin.gif
It's not all that uncomfortable, however it is nowhere as nice as the stock seat from my Cub Cadet GT /forums/images/graemlins/smile.gif I guess if I wanted to put some work into it, I could modify a bracket for a bigger, thicker seat. I don't have enough seat time to justify that ... yet.
/ YM 1700 Seat #19
Hi Bob can you move the fenders out any for more clearance? I made spacers and moved mine out 1 inch on each side and it gave me the clearance to put an nice TSC seat on mine. I just used some old skateboard wheels that I remove the bearing from to give me the added height. Take a look at the link for some ideas.
http://home.hiwaay.net/~n4bk/yanmar.htm
Bob in Morgan County.
/ YM 1700 Seat
Bob,
That is good information. I never thought about moving the the fenders out. I have turned around my tires and filled them with water. That gives me more clearance between the wheels and the fenders anyway. You guys are right about the Japanese model seats. It is one of those pan type with some cheap foam paddig and quite frankly is not wide enough for me. I like your tires too unfortunately, I think I still need the AG tires because my land is hilly and swampy in places. I have springs all over my property.
I don't want to highjack the thread but, I have also been looking into front weight as well. How much do the lead weights weigh?
CWARRIX,
Thanks for the pictures on the springs. I think I will try that until I decide what to do replacing the seat. A cheap upgrade is always a plus.
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
2000 Ford E-350 Shuttle Bus (A64194)
2000 Ford E-350...
2021 Caterpillar 279D3 Compact Track Loader Skid Steer (A64553)
2021 Caterpillar...
Small Cow (A64557)
Small Cow (A64557)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2021 BOBCAT E50 R2 SERIES EXCAVATOR (A63276)
2021 BOBCAT E50 R2...
