YFL 650 loader valve?
/ YFL 650 loader valve? #1
keenlanp
Dorr, MI
Branson 3015H, Yanmar YM 240D, YM 186D
Folks,
After spending too much time on marketplace and craigslist over the last couple years looking and a 15 hour round trip yesterday, I managed to buy a YFL 650 (and what was left of the tractor it came on) for my 186D. It had sat under a tree for a decade and I will need to replace most of the hoses, but the loader, bucket, and the subframe are all in good shape except for some surface rust. I am also not sure I can resurrect the loader valve. If not, I assume that pretty much any valve with the right flow capacity and #of ports/spools should work? Thanks as always for the wisdom.
/ YFL 650 loader valve? #2
I assume you've seen the other current thread about loader valves.
My post in there links to a long thread about them.
A couple of things I can add: YFL650 is an easily-removed loader so be sure to include quick-connects on the hoses. I thought mine dribbled so I replaced them -- then discovered new o-rings might have been a sufficient repair.
And I would make every possible effort to re-use the existing loader control even if you have to fabricate a replacement for the joystick monkey-motion. (Twin sticks might be a suitable replacement for that flimsy linkage).
Please post photos as you work on this project!
/ YFL 650 loader valve? #3
While I really like the way my joystick control works, I have a friend that needed to replace his valve due to leaks and it being non rebuildable. He went with a multi spool valve and set up his 3 function as an independent spool in the valve. I have never ran his and bern a while since we talked about it, but as I remember, he put the 3rd function next to the curl/dump spool saying he could do one with his thumb and hill of his hand and the other with his fingers. For him it worked. I believe he installed a couple of sets of remotes also. Not sure now if that was from a different valve or not.
Food for thought if you need to replace the valve.
Good luck with rebuilding the loader.
Surplus Center is a good source for hydraulic parts if you know the size and fittings you need.
If you do a new valve, be sure to match fitting threads when you order.
/ YFL 650 loader valve? #4
I have the same tractor, loader and the original mechanical linkages/single lever joystick loader. My 40 year old valve works, but is dripping and showing its age(no float or regen either). I am thinking of upgrading my valve as well. Look at the quality/rebuildable single lever Prince LVT1GR5AB7 10 GPM loader valve. American made valve with float for loader arms and regen for faster bucket tipping out. It has #8 pump ports and #6 work ports. Available for $350 online from DaltonHydraulics.com. Install and design specs are all listed on the Prince Hydraulics website. I researched similar and less expensive valves also, but saw many complaints of issues and failures 1 or 2 years after the replacement. I have never had any issues with other Prince hydraulic valves. I'm just about ready to pull the trigger and order that valve for myself. You get what you pay for I guess? Good Luck.
2010 KEYSTONE LAREDO (A65643)
2010 KEYSTONE...
John Deere CP690 (A64126)
John Deere CP690...
VOLVO ROLLER (A65053)
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
2018 RAM 2500 (A65643)
2017 Kubota L3901 (A64126)
2017 Kubota L3901...
