Yet another slightly offbeat assignment...
   / Yet another slightly offbeat assignment... #51
I agree.
With this long a thread for a fairly simple idea, there better be pictures to prove it worked.
Unless, of course, the client backs out. Then we'll expect a picture of the bail receipt. :rolleyes:
Defective said:
I agree. With this long a thread for a fairly simple idea, there better be pictures to prove it worked. Unless, of course, the client backs out. Then we'll expect a picture of the bail receipt. :rolleyes:
Well, two points on that. I really am in the process of buying the stump bucket anyway. Funds are allocated and I've only been holding back to see if I can combine shipping costs on several items I need... but I will have it here by the time this job gets done. I will be very tempted to test the "no cost" option before I go with the "low cost" option. :cool:
Also, I am running into considerable resistance on the part of clients to the photographing of their property/projects... both before and after the work is completed. I am down to only doing this now when large tree removal is involved (to forward to my tree guy) or when rental equipment is indicated (to show the task to the equipment rental folks). Everyone is crazy concerned about privacy and confidentiality these days. Posting the pix on the net makes it worse. I certainly don't mind posting pix of the plywood funnel if I do build it, but actual "action" shots are probably not gonna happen. Sorry guys! :eek:
Dougster
   / Yet another slightly offbeat assignment... #53
Dougster said:
Where are those 5 or 6 people with wheelbarrows when you most need them??? :D
All kidding aside, I get your point but for what I bid this job I would lose money bigtime if I had to hire 5 or 6 people to do the work.
Dougster
Hmm... how much dirt will a stump bucket hold, vs a wheelbarrow ? I dont think much more. If you load the wheelbarrows with a mini excavator, there's hardly any getting tired on the job, and people can cart on and off, which in the end will be quicker than the rock bucket because the wheelbarrow is so much more manoeuverable.
If you had to shovel it all into the wheelbarrows by hand, it would be too exopensive, but using the men on the wheelbarrows just to cart, this is a very quick and effective way as the kid who gets least tired, (on the exacavtor) sets the pace.
By the way, what exactly are manholes ?? manholes like they dug in WW1 ??
Renze said:
Hmm... how much dirt will a stump bucket hold, vs a wheelbarrow ? I dont think much more. If you load the wheelbarrows with a mini excavator, there's hardly any getting tired on the job, and people can cart on and off, which in the end will be quicker than the rock bucket because the wheelbarrow is so much more manoeuverable. If you had to shovel it all into the wheelbarrows by hand, it would be too exopensive, but using the men on the wheelbarrows just to cart, this is a very quick and effective way as the kid who gets least tired, (on the exacavtor) sets the pace.
I totally understand what you are saying... but I am a "one man and one tractor" show. No employees. Haven't learned to speak enough Spanish and Portuguese to pull that off yet. :rolleyes: I really wish that I could afford real legitimate employees... but that possibility is literally years away. And for what I bid this job, I couldn't afford to use any employees anyway. :eek:
Renze said:
By the way, what exactly are manholes ?? manholes like they dug in WW1??
Nope... nothing like that. These are abandoned underground utility compartments... that now allegedly pose a danger to the public if not filled in.
Dougster
   / Yet another slightly offbeat assignment... #55
Have you accepted and figured out how to accomplish this task?
   / Yet another slightly offbeat assignment... #56
Dougster, you mean manholes at cable joints, when the cable trenches were already backfilled ? If somebody dug trenches to install cables, wouldnt they keep the dirt nearby for backfilling ?
Or are the manholes permanent working pits, that are now no longer in use and needs to be filled because they arent needed any more ?
Sorry for asking dumb questions... ;)
Renze said:
Dougster, you mean manholes at cable joints, when the cable trenches were already backfilled ? If somebody dug trenches to install cables, wouldnt they keep the dirt nearby for backfilling ? Or are the manholes permanent working pits, that are now no longer in use and needs to be filled because they arent needed any more ? Sorry for asking dumb questions... ;)
Sending you folks PMs...
Dougster
   / Yet another slightly offbeat assignment... #58
Dougster,
Are you sure you know what you are getting into here? Flowable fill is like concrete with a real high slump (very runny with a smaller aggregate size).
I suppose you could kinda do the job with a dump trailer, FEL and funnel but it would be a real mess, and the stuff does set eventually. I'm not sure how long it stays workable (a couple of hours?), but you need to consider that.
Flowable fill makes sense for this job, but I didn't think about that because you kept saying sand.
Toiyabe said:
Dougster, Are you sure you know what you are getting into here? Flowable fill is like concrete with a real high slump (very runny with a smaller aggregate size). I suppose you could kinda do the job with a dump trailer, FEL and funnel but it would be a real mess, and the stuff does set eventually. I'm not sure how long it stays workable (a couple of hours?), but you need to consider that. Flowable fill makes sense for this job, but I didn't think about that because you kept saying sand.
The client is talking sand. The materials provider offered up a flowable sand mix which I took to be mean dry sand with other things added to assure good flow and distribution. The town will have the final say when I pull the permit. I apologize to all for my incorrect and/or ambiguous usage.
Dougster
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
2015 Chevrolet Tahoe, 192,897 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2015 Chevrolet...
1986 HMDE 6x14 Bumper Pull Trailer (A57453)
1986 HMDE 6x14...
2008 Keystone Camper Mod. 311BHS (A59814)
2008 Keystone...
