Yet another silly question
/ Yet another silly question #1
Ozarker
Veteran Member
Yanmar 1500D
Anybody know how to take this Curtis FEL off my Yanmar? I have no manual and can't find a website for Curtis.
I guess it should be a simple one-man operation but I just can't see how it actually comes apart.
There is a leg that is pined into the frame of the loader and it is clearly there for removal. I set it in it's holder in the center of the loader frame thinking that the bucket would sit down and the leg would act as a rear support allowing me to unpin the loader and back out. But when I sit it down on the leg, the bucket is still about 2' off the ground.
Is that leg supposed to be a balance point to allow two people, one on each side, to unpin the loader from it's attaching point and then lean it forward to back the tractor out?
Do I remove the brace that wraps around the front of the frame?
Anybody know where a web site for Curtis is?
/ Yet another silly question #2
The loader on my Yanmar comes off like this.
1 Insert the supports as you have described.
2 lower to the ground and roll bucket forward until the lip touches the ground.
3 Unbolt from the bottom of the vertical posts.
4 Now you can use the hydraulics to curl the bucket and also raise the vertical control until the posts will clear the tires.
5 Disconect hoses and back away.
Be careful and stay on the seat when you are using the hydraulics. We don't want you to get hurt. The process will be as clear as mud once you get started.
Thanks.
I kept looking at curling the bucket down to contact the ground and thought that might have something to do with the process. But I couldn't figure out how I would curl it back after I disconnected from the posts. It didn't occur to me to leave the hydraulics connected until I had it positioned so I could back out.
I have had this tractor for two years and never had a reason to remove the FEL before so I never tried to figure it out. But I have to replace the clutch now so off with the FEL.
Thanks again...
/ Yet another silly question #4
The procedure described sounds pretty similar to what I must do with my Kubota. Once you do it a time or two, it's a piece of cake and takes but a few minutes at most.
One thing, though. Be sure to do it on level ground! If you don't, one side is going to be uneven with the other and it's really a pain getting everything lined up to reattach.
Good luck!
Well, got part way through the process and had to put it all back together. The lines to the loader both have male ends and the connectors on the tractor line are both female. No way to close the hydraulic system after I disconnect the lines.
Guess I have to go have a short hydraulic line made up to bridge that gap. I'm guessing that whoever installed that loader gave the owner a line like that but he didn't pass it on.
/ Yet another silly question #6
See if you can swap a male for a female connector and you should be good to go!
/ Yet another silly question #7
/forums/images/graemlins/confused.gif If they are quick disconnects, you shouldn't have to bridge the gap. They seal themselves when disconnected and there is no need for hydraulic fluid to go from one to the other if there is no attachment hooked up to the lines. Mine have slip-on dust covers to keep the connectors clean, but no bridging hose. /forums/images/graemlins/smirk.gif
/ Yet another silly question #8
Careful! On some units you may disconnect and blow your pump. Make sure you know what you have BEFORE trying that.
/ Yet another silly question #9
Yep, both male and female ends should seal at least they do on mine.
There will be a little fluid drip on the female at first.
Don't go there....LOL
They are just threaded fittings.
/ Yet another silly question #11
<font color="blue"> I have no manual and can't find a website for Curtis. </font>
If it's the same Curtis company that makes cabs and snow blades, here is their site: <font color="red">http://www.curtiscabs.com/ </font>
OkieG
/ Yet another silly question #12
</font><font color="blue" class="small">( They are just threaded fittings. )</font>
Now you need to be careful. If you unscrew this right after the pump, then you will probably _need_ to connect the 2 ends as you want to do. If you are unscrewing this between the loader control levers & the loader, you will probably _not_ want them looped together. However, doing it wrong (and do not rely upon my assumptions - just know that it can be done wrong!) can really mess things up - like, serious pump breakage.
If it were me, I would sure want quick disconnects in there, only $20 or so a set, and then you can use other hyd equipment on your tractor when the loader is disconnected. Screwing 2-4 pipes apart each time is _not_ fun, and a person has a tendency not to cap the loader ends which lets oil out, dirt in......
--->Paul
You are absolutely correct. When it was installed, sometime before I owned it, they simply cut one supply line and attached the loader lines. This diverts flow through the loader valves I assume that they provided the other owner with a bypass hose but it didn't get passed on to me.
It is in the shop having a new clutch put in and the shop is going to make me a hose when they take the loader off.
/ Yet another silly question #14
Here is a picture of my control valve
/ Yet another silly question #15
Another pictere ready to back away.
2006 NORAM 65E MOTOR GRADER (A62129)
2006 NORAM 65E...
HOMEMADE FIRE PIT (A62131)
HOMEMADE FIRE PIT...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLF CART (A62130)
UNUSED SDLANCH...
UNUSED WOLVERINE TDM-11-78W 78" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
John Deere 5045E for sale
John Deere 5045E...
2016 CATERPILLAR 259D SKID STEER (A62129)
2016 CATERPILLAR...
