Yard Hydrants
/ Yard Hydrants #21
I agree about the concrete personaly,but a 18"x2" pad breaks up easy with a sledge and only cost a couple of bucks to put down and makes a nice base for the hydrant.I find it hard to believe someone would run a line and stick galv pipe with a stop on it any where theres a chance of freezing.All the trouble of running a line somewhere just to jimmy it up.
/ Yard Hydrants
That is an excellent ideal....backflushing the line if it wont drain. Are there any tell tale signs that the hydrant is not draining sshort of it freezing up?
/ Yard Hydrants
/ Yard Hydrants #24
</font><font color="blue" class="small">( Hmmm. Do ya suppose it just might get a bit colder in Utah than it does in Arkansas?
Nah, couldn't be. If it worked in Arkansas it MUST work in Utah!
Except it won't. Galv pipe will break in Utah. )</font>
Actually, I'm talking about a system that I put in just south of Ogden, Utah. -- You're replying to me about Arkansas -- where's that coming from?
1. There was no mention earlier of needing to keep water running in the system all winter...
2. If you shut off the water to a system with self-draining valves, they will drain the water out of the lines... it takes water pressure in the line to keep those self-draining valves closed.
I had seven manual lawn sprinkler lines set up with self-draining valves set at low points in each line, in addition to two similar irrigation lines run to opposite corners of my garden. On the irrigation lines, I used 4' sections of galvanized pipe to come up out of the ground. I had two valves on each pipe. One, at the top was a shutoff valve, and above it was a brass "Rainbird-type" sprinker head. Farther down the pipe, I used a 'tee" and put in a normal spigot for using water hoses (primarily soaker hoses). I could close the shutoff valve, and the spigots worked just like one attached to the house. Or, I could open the shutoff valve (closing the spigot) and use it as an elevated sprinkler. With one at each corner of my 60x60 garden, I could water the entire garden that way. Or, I could use soaker hoses or smaller sprinkers from hoses on the spigots....
At the end of the season, I turned the water off to the lines, opened the spigot and the shutoff valve, and the water drained out so the line wouldn't freeze...
Not sure if this applies to the original poster's needs, because he still hasn't said exactly what he intends to use these hydrants for, or whether they need to be used in the winter...
Others are jumping in with their assumptions... but he hasn't said....
Galvanized pipe will freeze and burst in Utah if you leave water in the lines -- any type of pipe will that I'm aware of...
/ Yard Hydrants #25
/ Yard Hydrants #26
Mace,when you turn the hydrant on you should notice that it has to fill the galv pipe up before water shoots out.If you have instant water with a hydrant it has a problem.And that sounded like a good way to try to flush it out if thats the problem.Mostly the problem ones were put in clay with no way of draining.
/ Yard Hydrants #27
/ Yard Hydrants #28
I installed the 6 foot hydrants, 4 foot under ground and 2 foot above ground. I used the black 1 inch polly for my supply lines. The drain back at the base of the hydrant I put in a 5 gallon bucket with the bottom cut out of it filled with pea gravel and wrapped in fine meshed high quality landscape cloth to try to keep dirt from getting into the pea gravel.
In some areas you are not supposed to use the drain back because of the fear of well/supply contamination and if the hydrant is inspected the inspector will make you plug the drain back and set the system up as a flush type system.
The frost line in my area of Michigan is 42 inches. You need to find out what the frost line is in your area and dig your trenches to the appropriate depth to keep it from freezing.
My system has been in place for 4 years and have not had a problem with it.
Farwell
/ Yard Hydrants #29
Farwell
/ Yard Hydrants #30
Kent, it came from HERE:
<font color="blue"> save your money and just install galv pipe coming up with a faucet on the end: it will freeze, but it will not burst, unless you try to cover it up to protect it: do this on the ones your definetly not going to use when the temp is below freezing, and save youself a lot of money and future work...repairing messed up yard hydrants...been there.. heehaw </font>
/ Yard Hydrants #31
/ Yard Hydrants #32
Here's a link to a yard hydrant that has a self contained drain chamber. should eliminate any concerns about adequate drainage, i.e. in clay soil or high water table.
/ Yard Hydrants #33
/ Yard Hydrants
I want to be able to use them all winter.
/ Yard Hydrants
/ Yard Hydrants #36
</font><font color="blue" class="small">( Kent, it came from HERE:
)</font>
Heehaw is from Arkansas, not me -- that scattergun you're using is dangerous....
/ Yard Hydrants #37
)</font>
/ Yard Hydrants #38
i have seen galv pipe sticking up 2-3 ft with a faucet on the top, all the way up in Pa; and yes they do freeze, but no, they do not split or break, unless you put a shutoff valve in line and shut it off, or try to cover it up: as long as they are left out, they will freeze from the top down, and push the water back down the line, you try to cover it up or put a shut off valve in and it will freeze at the ground first and then come up the pipe and split the pipe: or freeze and have no way to push the water back down the line(shut off valve) and it will burst..
heehaw
/ Yard Hydrants #39
heehaw
/ Yard Hydrants #40
the faucets i put in are not usable in really cold weather of course: but where folks are getting broken pipes with this method, is when they "shut the water off to the faucet", which means putting a shutoff valve in line, so the water can't be "pushed" back down the line when it freezes: i have seen a couple folks stick a 5gal bucket over the pipe, and of course, it doesn't sit on the ground well enough to keep the cold air out, so the pipe freezes at the ground, and then the pipe burst. 20 years ago, i put in 4 yard hydrants: the one i use the most was replaced twice, so the third time, about 5 years ago, i changed it to this method: since then 2 of the others have rusted shut and broke when i tried to use them, so i am changing them too: the 4th still seems to work fairly well.
heehaw
2018 John Deere 470G Hydraulic Excavator (A61572)
2018 John Deere...
Caterpillar D4 Dozer Parts and Service Manuals (A63117)
Caterpillar D4...
2001 Wellcraft Boat w/ 2000 Boat Trailer, (A61574)
2001 Wellcraft...
2009 STRICK 53X102 T/A DRY VAN TRAILER (A59912)
2009 STRICK 53X102...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
