Yanmar YM2000A-A pictures
/ Yanmar YM2000A-A pictures #1
rbhoppe
Yanmar YM2000A-A
Hello all, now that I know what tractor I have thought I'd share some photos for reference. I know when I was trying to figure it out I couldn't find pictures that matched, so hope this helps someone. While looking at the pictures I noticed I have a check chain pin just about to fall out...I'll get that fixed next week :).
/ Yanmar YM2000A-A pictures #2
Looks as though the wiring to the dash and switches are different than mine. Esp. At the Radiator drain were you have a fusible panel? One switch looks different Under the Tac. I Don't have that or the Fuel bowl to the Thermal start. Which I never use. Nice Tractor! The TR20A-A only seen a few! I added Front weight ballast By adding old Anchor lead from a local lake I collected over the Yrs.. Helped a lot without any complaints. My FM would lift the front wheels almost off the ground if it was 3Pt. lifted. Small bump in my gravel and you could tell it.
I was looking at a parts manual just now for the YM240 and noticed that the engine serial number doesn't match the 2TR20A but does match the 2TR20A-X. Did they mix and match engines among models?
Thanks, I really have no idea if there were modifications before I got it, this was my first tractor I've ever owned, I am quite the newbe. I mean I only discovered the compression lever just a few months ago after having it for 2 years :). So any info/advice/criticism is appreciated.
/ Yanmar YM2000A-A pictures #5
Mines Org. With Typical repairs. Like your Starter has been rebuilt and has the same Gold coil. I have a 195/240 Operators manual If you want it! PM me or Personal message me and I can Email it to you. Files to big for TBN.
UNUSED 2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
UNUSED 2023 VOLVO...
(1) 48"X7 1/2' ADS DRAINAGE PIPE (A60432)
(1) 48"X7 1/2' ADS...
Dodge Charger (A56859)
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
UNUSED FUTURE BOBCAT-E SERIES EXCAVATOR (A60432)
UNUSED FUTURE...
2018 VOLVO EC480EL EXCAVATOR (A60429)
2018 VOLVO EC480EL...
