Tiller yanmar tiller
/ yanmar tiller #1
dirt clod
panama city and altha florida
Kubota L3300, m5700, case 580se
a local dealer has for sale 5 foot yanmar tillers. They looked to be refurbished with new blades. He gets $725 for them. He said I may need a longer drive shaft. Theres no slip clutch on this. I didnt see any place for a shear pin either. Are these any good for foodplots gardens and such or were these just good for the rice patties they was made for?
Yanmar tractors also have several pto speeds some much higher than 540. was these tillers designed to work at higher than 540? I've got a kubota L3300 and the soil here is mostly sand with some clay at about 8".
/ yanmar tiller #2
You might want to ask on the Yanmar forum. A lot of people on there have them.
/ yanmar tiller
thanks for the info. i'm sure the tiller would work good with a yanmar tractor i was posting here to see if anyone was useing on something other than yanmar and if the 540 pto speed worked ok.thanks for the reply though.
/ yanmar tiller #4
I have a Yanmar tiller but I use it with my Yanmar tractor. I couldn't ask for a better tiller. The tiller will operate at different pto speeds. I use the 540 pto speed for breaking ground and the 770 speed for finishing the seed bed. Any faster speed in this Tenn clay will pulverize the soil and after a hard rain you have concrete. In my opinion he is a little high. In this area 3-pt Yanmar tillers sell in the $400-600 range depending on condition.
/ yanmar tiller #5
Make sure the new tines are Japanese. I bought some "bargain" tines that came from China. The tiller spit them out in pieces the first hard spot.
/ yanmar tiller #6
I've used my Yanmar tiller behind my NH TC18 quite a few times without any problem. I used to run it behind a YM1700 in all PTO speeds. It does work well with 540 though.
/ yanmar tiller #7
I use the yanmar tiller with my 2015 mahindra. It does good job at 540rpm pto speed.
/ yanmar tiller #8
Sounds a bit pricy. I bought a 4-ft Yanmar RS1200 for $300 last year. Blades look OK.
/ yanmar tiller #9
A friend of mine has had one so long and used it so much that he's put 4 sets of tines on the thing. He really likes the tiller. Sorry don't have a clue how much he paid for it.
/ yanmar tiller #10
I have the 1200 also. Got it for ~$400 but had to replace all tines, so ~$600 total. I like Flusher's deal better but I was lucky to get anything around here. I put a clutch on mine and cobbled up new lower 3PH mounts.
/ yanmar tiller #11
I have a Yanmar RCB 1500 that I use behind my Branson 4220 i tractor. I like it just fine. I use it for a garden spot about 100 by 70 feet. Its quiet and does a good job. On really packed hard clay, it bounces some. I remedied that by switching to 1000 RPM on my PTO, running about 1800 engine RPM, and using my lowest granny gear to inch through t the hard pack at a slower pace. Second or succeding tillings, I used 540 RPM and a little faster tractor speed and engine RPM, and it does great, with minimal bouncing or vibration. If I can attach a picture, I'll send it. I dont have a clutch on my driveline, either. Wish I had one.
Hope this helps.
2017 Mitsubishi Fuso FEC72S Landscape Truck, VIN # JL6BNH1A9HK003132 (A65563)
2017 Mitsubishi...
2012 Ford F-250 6.7L Diesel, 4WD (A62679)
2012 Ford F-250...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
Cute Electric Car (A62679)
Cute Electric Car...
