Yanmar tiller
/ Yanmar tiller #1
OhioGuy
Platinum Member
Northeast Ohio
Ford 1220, Case 245, Cub SZ60, Cub 2284
I bought a 1301 in the spring and got my first chance to put it to work today. My last attempt to till, I raised the tiller binding the PTO shaft and broke the universal. I cut down a new one this weekend and also made a shorter toplink out of an old piece of steel. It tilled really well but I have a couple of questions.
I tilled a fairly level piece of ground and ended up with some valleys that tilling again didn't remedy. Was that a result of uneven speed?
Also, not having a shearpin really makes me nervous. Today I was moving super slow and it seems like a couple of roots and stones caused some pretty serious vibration back there.
Any suggestions, my biggest fear is damaging the tractors PTO.
Thanks,
Curt
/ Yanmar tiller #2
I have four foot Yanmar tiller for about five years with no problems. The rear wheels leave tracks, but I just use the to plant rows. I kept the center link from my yanmar when I bought the Kubota and it fits perfectly.
/ Yanmar tiller #3
I have found that since my tractor doesn't have draft control that the tiller does the opposite of the front wheels. However, I don't recall having any real valleys except at the end of passes. I also usually cross till to help eliminate spots that are tilled shallow due to the front being "down".
To keep from binding up my pto shaft I made a "stop" which I put on my 3pnt control to keep from raising the tiller too high.
I don't have a shear pin or clutch either and have found that so far, knock on wood, it tends to simply climb or jump over obstacles.
/ Yanmar tiller
I replaced my lift arms with a set approximately 6" longer and it corrected the PTO shaft binding problem . I can lift to maximum height without binding. I use my standard length arms for my RM 59 and rotary cutter.
Curt
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2011 Ford Explorer (A64127)
2011 Ford Explorer...
Ford N Series Tractor (A66285)
Ford N Series...
11in. Tooth Excavator Bucket (A64194)
11in. Tooth...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
Pat's QH and hydraulic top-link.
Pat's QH and...
