Yanmar F395D
/ Yanmar F395D #1
search4one
Red Bluff, CA
Yanmar F395D Branson 4720I
Recently purchased a Yanmar F395D. The day after I purchased it was the first time I was introduced to the phrase "grey market."
The back cap of the hydraulic pump is cracked. The back pump was replaced at some time and has no numbers on it. If there are any other F395 owners that could help me out with numbers from their pump, it would be greatly appreciated.
Randy Baker
Red Bluff, CA
/ Yanmar F395D #2
What is the back pump? is this an injector pump that has its own oil?
I guess it has two hydro pumps? Does this one the power steering pump maybe?
/ Yanmar F395D
The back one is for the 3 point and FEL. The front one is for the power steering.
/ Yanmar F395D #4
Must be very similiar to this FX24D. I think Hoye stocks both the power steering and hydraulic pump for it. Sure it is probably different than your F395. You need a parts manual with numbers.
/ Yanmar F395D
Yes Winston1, from that angle it does look the same. Is this your tractor? If so, could you take some more pictures at different angles. It would be a dream come true if it was the same.
The cover plate on the pump in front it is stamped "PWI - C - 9C" Might be "PW1" The pump in the back on mine has been replaced at some point and there is nothing stamped on it. Which is what about 90% of the problem is. None of the parts suppliers seem to be able to find out what pump it is supposed to be and if the one on the front is the same as the one on the back. I have pictures but I haven't made enough posts to be able to supply a link.
I would buy a parts book in a heart beat but from what I am told they are only available in Japanese.
I guess the model tractor I have is some kind of off ball. Some of the suppliers won't even talk to me about it.
Thank you,
Randy Baker
Red Bluff, CA
/ Yanmar F395D #6
All the greys parts manuals are in Japanese, however, the pictures and part numbers can be very valuable. No, not my tractor, one I worked on a few years back. I looked through all my pictures on it and that is the only one showing the pumps.
The part number for the power steering pump in the FX24D manual is 194556-41120. It has a 7-C in the description field. The part number for the 3 point pump is 194555-41120. It has 9-A in the description field. Both those numbers will pick up in Hoye's "search" field. I doubt either pump is same as yours. I'm sure Hoye could tell you whether the pump is available or not.
This guy is very good at finding hard to come by parts. Sheaffer's Town & Country Tractor
By the way, welcome to the forum. :welcome:
/ Yanmar F395D
Thank you for the information and I will look into a parts manual.
I don't know if the pumps would be the same or not but it is worth a look. My tractor is 40 horse power, not sure if they would have the same pump on a 25 horse power.
Again, appreciate the info. and also the welcome.
Have a good weekend,
Randy Baker
Red Bluff, CA
/ Yanmar F395D #8
Hi Randy from the picture it looks exactly like the one on my F395D. Also if you look just above the pump that is the little generator that I need. I wish there was some place here in Canada to get it ???
Joe
/ Yanmar F395D #10
I wonder if that alternator and its matched regulator would serve as a replacement for the less powerful and more expensive similar set on earlier small Yanmars. The appearance looks identical so it should mount in the same space.
/ Yanmar F395D #11
part# 194521-41521 end cap for FX305-D:newhere:
/ Yanmar F395D
Thank you for the part number Ernie. Would you happen to know the part number for the pump itself. The rear pump for the three point and FEL. I'm being told that the end cap by itself is not available.
Thank you,
Randy Baker
Red Bluff, CA
/ Yanmar F395D #14
Thank you,
Randy Baker
Red Bluff, CA
Call Hoye Tractor. Yanmar USA wont talk to you about a grey tractor.
/ Yanmar F395D #16
I've tried Hoye Tractor but without a part number they don't seem to be able help.
You're going to need to buy a Parts Manual to maintain that thing. Text will be Kanji but diagrams and numbers are there, and that's what's important.
Once you have part numbers, it is likely the part you need appears on other models, particularly if its a hydraulic pump.
/ Yanmar F395D
Tried that as well, no parts manuals for this model are available. Seems I bought the odd ball of gray market tractors.
/ Yanmar F395D #19
Search4one, Leonard is the guy whose websight I attached in post #6. Have you tried him?
/ Yanmar F395D
Yes, I have talked to Leonard. Again no luck without a part number. I did email him a couple of days ago and ask if he could get me a parts manual but have not had a reply.
Great Dane Van Trailer (A63689)
Great Dane Van...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
Cat CB24B (A60462)
Cat CB24B (A60462)
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
New Holland 216 Rake (A63688)
New Holland 216...
