Tractor Sizing Yanmar Excavator Engine Size
/ Yanmar Excavator Engine Size #1
CharCur
Oxford, NC
JD4400, JD850, JD275, JD Gator TX
Can someone help me identify the size in my Yanmar Excavator YTB 1300S.
I did not look for a tag on the motor today and now it is dark so I figured I would ask the experts. I was using the excavator today and the water pump went out. I reckon I need the engine size to order the correct water pump.
If someone knows what water pump I need that would be even better.
/ Yanmar Excavator Engine Size #2
I have some Yanmar excavator parts books, but not one for your excavator. It is not a very common model. If you can provide the engine model, I should be able to supply you with a waterpump.
Lens,
The number on the motor is 3T80L-80592.
I need a water pump and a glowplug.
Can you furnish Part Numbers?
Thanks
Skid Steer Tree Puller (A65640)
Skid Steer Tree...
2016 COTTRELL CX09LS2 T/A CAR HAULER TRAILER (A59914)
2016 COTTRELL...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
Cattle Feeder (A65640)
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
