Yanmar 3110D
/ Yanmar 3110D #1
Jose
Hi for all of you,
I’ve got a Yanmar 3110D and would like to know how the gear box work since it seems it comes with two gear box. One is automatic (N -> 1 -> 2 -> 3) and the other come with C -> 1-> 2 -> 3 -> 4. How to work with this gear?
Rgds
Jose
Mozambique
/ Yanmar 3110D #2
One is a range selector, and the second is the gear selector within the selected range. The one with the regular gear shift is the range, and requires use of the clutch to shift. The other with the push button is the gears within that range. It can be changed without the clutch. There should also be a "R" before the N-1-2-3. This xmission can be shifted directly from forward to reverse. I don't recommend it unless going very slow, but it is great for loader work.
/ Yanmar 3110D
Hi,
So what is "C" for? If I use , for instance, on range selector "3", which gear can I use for speed?
Rgds
Jose
/ Yanmar 3110D
Another thing: Why did you say "great for loader work"?
Sorry for all this question but I would like to understand how this works!
Rgds
Jose
Mozambique
/ Yanmar 3110D #5
It is good for loader work because you are typically doing repetitive forward/reverse shifting. The ol' clutch mashing leg gets tired after a while. With the powershift you dont need the clutch. Creep is V E R Y slow and is great for tilling. On some tractors it is hard to tell if the tractor is actually moving.
Aaron
Parts@HoyeTractor.com
(940)438-0386
/ Yanmar 3110D #6
As Aaron said "C" is for creep. All the gears will work as in the other ranges. Just slow, slower, slowest etc.
/ Yanmar 3110D
Hi,
I know it could be boring, but if I want to movie on the road with relative speed, which gear do I must use? What I understanding the reverse and forward is made by the automatic gear (R, N, 1,2,3,)!
Rgds
Jose
/ Yanmar 3110D #8
Jose, 3rd gear in range 4 should give you road speed (top speed) and dont think you wolud want to use any implements at / in that range. BTW How did you make out with the FEL measurements? Mark
/ Yanmar 3110D
Hi Mark,
Tnx for all your support. Regarding FEL I didn't yet. I’m looking all pictures I can get on Internet before I decide to make my self one. Will be hard job because I can’t get any plans and using only picture will be complicate.
Rgds
Jose
Mozambique
/ Yanmar 3110D
I know that. But there's no way at moment send money to outside. There’s a rule here in Mozambique that becomes very difficulty to send outside money! Tnx nway.
Rgds
Jose
Mozambique
/ Yanmar 3110D
Hi,
For sure will be helpful!
Tnx pal
Rgds
Jose
Maputo - Mozambique /forums/images/graemlins/wink.gif
/ Yanmar 3110D #14
Mark; Would like to see those loader plans. The link you provided doesn't appear to work. I just get page cannot be displayed.
/ Yanmar 3110D
Hi
One thing more: does any one know which front tire’s size use this tractor (3110D)?
Rgds
Jose
Mozambique
2022 EZ-GO ELITE...
2020 International LT625 48" Sleeper (A62613)
2020 International...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
New/Unused Quick Attach Open Back Mounting Plate (A65583)
New/Unused Quick...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
