Yanmar 240 What is This?
   / Yanmar 240 What is This? #1
Dan0
Menifee, Ca.
YM 240
The cover with the 2 allen bolts are leaking. it is the part above front axel that is painted Gloss black with the paint coming off and some kind of rubber round boot on the bottom. tractor oil pump.jpgtractor oil pump.jpg
   / Yanmar 240 What is This? #2
My guess is a hyd pump....
I need to find a gasket, the front cover is leaking and I can't find the image on the net.
Could not find anything there. Hope someone else chimes in.
   / Yanmar 240 What is This? #6
Call them on Monday. They post on here but not every day..
   / Yanmar 240 What is This? #8
The cover with the 2 allen bolts are leaking. it is the part above front axle that is painted Gloss black with the paint coming off and some kind of rubber round boot on the bottom.View attachment 683343View attachment 683344
It's the Hydraulic Pump 7cc
Pg 172 thru 176 in the YANMAR YM195 YM240 PARTS MANUAL 000Y00T2381.PDF Over at the Yanmar Tractor Owners Group on GroupsIO.
   / Yanmar 240 What is This? #10
It's a hyraulic pump. There are two hydraulic pumps on the YM240 - one low pressure type for the engine oil and one much higher pressure and flow rate for the 3pt operation. Checking the oil that is leaking will tell you which one you are dealing with. Engne oil is typically black with soot. Trans/Hydraulic oil is clear to milky. BTW, milky = water in the trans/hydraulic system.
Either way, I wouldn't just jump up and try to cure a leak unless it is leaking enough to lower the oil level. Here's why:
Hydraulic pumps generally don't have gaskets. They are made to an extremely close tolerance with polished surfaces and sealed with O-rings.
The type of O ring is critical, and you want an original Yanmar rather than a USA replacement O ring. We can talk more about the difference in O rings if there is any interest.
But before doing anything, you should check which pump it is and if the oil level is low.
Here's some YM240 info:
  • YM240Hydraulic System Workshop manual.pdf
(INOP) MASSEY FERGUSON 2614H RIDING MOWER (A58374)
(INOP) MASSEY...
JOHNSON JW12 OUTBOARD MOTOR (A58374)
JOHNSON JW12...
PICNIC TABLE & BENCHES (A58374)
PICNIC TABLE &...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
golf cart (A55787)
golf cart (A55787)
