Yanmar 225d No Tension on Clutch Pedal
   / Yanmar 225d No Tension on Clutch Pedal #1
hoffmanfarm
Yanmar 226D
I recently removed the transmission to replace gaskets. I have it completely back together now. But I have no tension on the clutch pedal. It doesn't automatically come back when I release it and it feels like it isn't really doing anything when I push in. I'm beyond frustrated at this point. Any ideas would be very much appreciated.
   / Yanmar 225d No Tension on Clutch Pedal #2
I've never been inside a Yanmar and you've probably noted the obvious stuff, like how the clutch felt before you dismantled it. On a car there's no reason to remove the pressure plate from the flywheel when removing the transmission. I don't know if this is the case with a tractor. Are you sure your clutch adjustment is correct? Is the linkage installed correctly? How about the fork that moves the throwout bearing? You've probably already gone over all this stuff but it never hurts to rethink the process. Something might come to you.
   / Yanmar 225d No Tension on Clutch Pedal #3
Is the clutch engaged or disengaged?
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
LMC LOT NUMBER 142 (A53084)
LMC LOT NUMBER 142...
2016 Atlas V4 Towable Light Tower (A51691)
2016 Atlas V4...
2018 JOHN DEERE 5075GN LOT NUMBER 100 (A53084)
2018 JOHN DEERE...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53472)
2019 Krause...
