Yanmar 225d No Tension on Clutch Pedal
   / Yanmar 225d No Tension on Clutch Pedal #1
hoffmanfarm
Yanmar 226D
I recently removed the transmission to replace gaskets. I have it completely back together now. But I have no tension on the clutch pedal. It doesn't automatically come back when I release it and it feels like it isn't really doing anything when I push in. I'm beyond frustrated at this point. Any ideas would be very much appreciated.
   / Yanmar 225d No Tension on Clutch Pedal #2
I've never been inside a Yanmar and you've probably noted the obvious stuff, like how the clutch felt before you dismantled it. On a car there's no reason to remove the pressure plate from the flywheel when removing the transmission. I don't know if this is the case with a tractor. Are you sure your clutch adjustment is correct? Is the linkage installed correctly? How about the fork that moves the throwout bearing? You've probably already gone over all this stuff but it never hurts to rethink the process. Something might come to you.
   / Yanmar 225d No Tension on Clutch Pedal #3
Is the clutch engaged or disengaged?
JOHN DEERE R4023 LOT NUMBER 261 (A53084)
JOHN DEERE R4023...
2001 Dodge Ram Wagon 3500 Passenger Van (A51692)
2001 Dodge Ram...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A52576)
2019 FREIGHTLINER...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
KUBOTA MX4700D TRACTOR (A51247)
KUBOTA MX4700D...
