Yanmar 2010 alternator conversion
/ Yanmar 2010 alternator conversion #1
ufengineer
Jacksonville, florida
ym2010
Is there a simple kit to convert over to an alternator. Alternator and brackets, wiring diagram .....
/ Yanmar 2010 alternator conversion #3
Look in Test you Reg.
Winston
Where did you get your mounting brackets. The flat stock in particular. What size square stock did you use. Aside from the wire that goes to the starter/battery, did you connect the other wires to the regulator plug or did you connect to the fuse box or some other place.
I haven't been able to find my fuse box yet �� .
/ Yanmar 2010 alternator conversion #5
Winston
The flat bar was just a piece of 1/4" scrap. I used a torch to cut the shape.
The square stock was 1" od.
It has been two years and my old mind cannot remember just how I hooked up. The earlier attached thread will give all the information I remember. Neat 1500 and others are very knowledgeable on electrical and I am sure will help you.
Your fuse box in sort of left of the steering wheel and under the dash.
Finally, unless you are having unusual trouble or need lot's of juice I would advise against making the change. It is tricky getting the alternator in the available space. It can be done . :thumbsup:
Thanks Winston. I'm going to replace the regulator for now and see how long it lasts. The regulator I took out looks to be the original one. It has a Japan markings on it.
Would any rs5101 regulator work. I can get one off eBay for 36 bucks or tractor supply has them for around 70 bucks.
/ Yanmar 2010 alternator conversion #7
I have the Old Style Reg. and New... Want one? And I even still own a yanmar tractor.....
/ Yanmar 2010 alternator conversion #8
"And I even still own a yanmar tractor....."
Guess this was directed toward me?
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
2016 Hyundai Box Trailer (A62613)
2016 Hyundai Box...
New/Unused Quick Attach Open Back Mounting Plate (A65583)
New/Unused Quick...
Frontier Hay Spear (A64126)
Frontier Hay Spear...
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
17395SFL (A61568)
17395SFL (A61568)
