yanmar 2000
/ yanmar 2000 #1
bruce60
Frisco
yanmar2000
I think I seen somewhere on this site if tractor starts and died and if there is water bubbling in radiator this means????
/ yanmar 2000 #2
I don't know the starting and dieing has anything to do with the head gasket but constant bubbles in the radiator is likely a blown head gasket.
/ yanmar 2000
Thanks that's what I was afraid of.
/ yanmar 2000 #4
A big chain auto can rent a gauge that goes on the Radiator Cap to see what the pressure is or if it's even building up. There has been absolutely no mention of it running hot or any signs of it. Water Loss, Water In the oil. Excessive smoke! Must have just happened.
/ yanmar 2000
Yeah just happened after using it for an hour.
/ yanmar 2000 #6
Flush the Radiator. And see what happens. Bubbles could be a dirty Radiator. I would start there and see about checking the pressure. With no loss of water mentioned it may be the Radiators Plugged up.
/ yanmar 2000 #8
An old school trick is to place black pepper in the radiator. If the exhaust smells spicy, then the head gasket is blown. Black pepper is also a trick to seal small radiator leaks too without clogging cooling ports in the cooling system.
Whatever you do. never use the stop-leak radiator stuff with metal shavings. That will cause all sorts of problems.
/ yanmar 2000 #9
Maybe change up your thread titles and not use the same one on everything. It gets a bit confuseing. Maybe call it "yanmar 2000 head gasket?" or something similar and the same with the other ones. give us an indication of the issue or problem in the title. It helps keep them straight. So we can be like of this is the head gasket thread from bruce or this is the oil thread from bruce.
We need a resident modd in the yanmar section so we dont have to go find someone or bug mohamed.
/ yanmar 2000
Okay sorry about the thread issue. Will do.
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
3144 (A63117)
3144 (A63117)
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
Ford 3910 Tractor (A65579)
Ford 3910 Tractor...
New/Unused Quick Attach Backing/Mounting Plate (A65583)
New/Unused Quick...
