Yanmar 187D
/ Yanmar 187D
Hi Guys, me again. I have been messing around with my new toy like a kid at Christmas time and haven't checked this for a while. Hey Whiskey, thanks much for the offer, as soon as I find someone with a fax machine I will get you a number. I really appreciate the help and info everyone has given me and as soon as I get it cleaned up a little I will post some pictures.
/ Yanmar 187D #12
Wheeser:
Maybe a little bit of a mess being the pages are printed front and back but I could scan then and email, deponds what you need and how many pages.
/ Yanmar 187D
Hey, that sounds great. I would need the listing for the clutch pack assembly
Hi/Low range, parts list and general break down of how things come apart.
Thanks Whiskey, I appreciate this.
Wheezer
/ Yanmar 187D
Hey, I didn't forget you guys, been a little busy with the "LITTLE BEAST".
Wanted to post some pictures but I can't figure out how. Thanks to everyone who helped out with info etc, I'm getting ready to tear into it and get it fixed. Also someone told me over the weekend that they can cross reference J.D. parts for Yanmar, any truth to that ?
/ Yanmar 187D #15
"Also someone told me over the weekend that they can cross reference J.D. parts for Yanmar, any truth to that ?"
I doubt it, never heard of it, but why would you want to?
/ Yanmar 187D #16
Wheezer:
I would be surprised if some one could but, by now you should have the part number and with the help of a good John Deere Dealer I would not be surprised if he could make if happen....being you suspect it to be a range gear and the fact thet Deere and Yanmar were buddies for so long it could be that the same range gear is used back when Yanmar built Deeres compact line of equipment.......don't count on it.....
Anywho, here's a link http://www.yanmar.com/tractor/dealerlocator.asp click on your state and you'll get a list of your local dealers if none are still in biz I have a local authorized Yanmar Dealer that would ship out parts...or the dealers on this site could get you the part I would guess.
/ Yanmar 187D #17
It could be something like a shift fork in the transmission. can you take the top off where the range shtf leaver is look. I once had a cub that had no second gear and all dhis required was a little refurb to the fork and it worked fime. Someone may have jammed the leaver and broke the shifter not a gear.
/ Yanmar 187D #18
"Help--Im looking at a 187D with loader but there is a problem with the 3rd range, 1st and 2nd are fine but when you put it in third high range it won't move the machine and will stall it out at idle."
I originally missed the part where you said it stalls, I assume you mean when you let out the clutch try to go forward. I suspect it is attempting to select 2 gears due to a bent shifter fork or sheared pin. You will probably find the problem if you remove the cover.
Deere 410L (A53317)
Deere 410L (A53317)
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2007 Ford F-150 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
2008 KALYN SIEBERT TRI PLEX FRAC PUMP (A60736)
2008 KALYN SIEBERT...
2023 Dodge Durango SUV (A59231)
2023 Dodge Durango...
